ᐅ Which assembly steps are especially important when building IKEA BRIMNES furniture?
Created on: 19 Apr 2022 10:03
Lakira
Lakira
19 Apr 2022 10:03
I recently purchased the IKEA Brimnes furniture piece and am now about to assemble it. Since I know that certain assembly steps can be crucial, especially with IKEA furniture, I would like to ask for your experiences: Which assembly steps for the IKEA Brimnes are particularly important to ensure a stable and fully functional piece at the end? Are there any common pitfalls or tips to be aware of, especially regarding the fit of the parts, the order of assembly, or handling screws and dowels? I look forward to precise and helpful advice to make the assembly go smoothly.
JORGERON
19 Apr 2022 11:18
It is especially important to first sort and check all the parts. Then carefully attach the back panel, as it provides stability. Screws should always be tightened securely, but not overtightened.
Deandre
19 Apr 2022 13:47
Hello Lakira,
I understand your question well, especially since preparation is crucial with more complex furniture like BRIMNES. In my opinion, these points are important:
- Check and sort all parts before assembly
- Follow the instructions exactly in the given order, especially when assembling drawer fronts and hinges
- Do not tighten screws and dowels too much to avoid damaging the material
- Pay attention to the alignment of the back panel, as it stabilizes the entire structure
Sometimes it is also helpful to initially tighten screws loosely and then fully tighten them at the end to allow some adjustment. If you are less experienced with tools, I recommend using a cordless drill with adjustable torque. Hope this helps!
Fitigu
20 Apr 2022 09:02
Lakira schrieb:
Which assembly steps are especially important for IKEA BRIMNES to end up with a stable and functional piece of furniture?
Basically, the following assembly steps are particularly important for BRIMNES:
- Sorting and checking all parts carefully before starting
- Correctly and carefully attaching the back panel, as it stabilizes the side panels
- Precisely fitting the dowels and securing the connections with the corresponding screws
- Following the assembly sequence, since some parts like hinges and drawer fronts are installed later
A reliable approach prevents twisting of the furniture and enhances its durability.
edisonbla
20 Apr 2022 14:15
JORGERON schrieb:
Screws should always be tightened well, but not over-tightened.
Absolutely! Nothing is more frustrating than realizing during assembly, "Oops, I’ve messed up the screw." With BRIMNES, I also find that precise alignment of the drawer rails is crucial. A drawer can easily be ruined if the runners are not positioned correctly.
Also, I recommend always working on the floor to avoid accidentally scratching parts. If you keep that in mind, assembly can even be enjoyable!
PEDRO40
21 Apr 2022 08:46
Deandre schrieb:
If you’re less experienced with tools, I recommend using a cordless screwdriver with adjustable torque.
I can only emphasize that. When I assembled my first BRIMNES, I initially had doubts about the precision.
I would advise taking plenty of time at the start, especially when attaching the back panel and the drawer slides – this requires a delicate touch to ensure everything works perfectly in the end. Applying too much pressure on screws or misaligned components can cause drawers to squeak or the furniture to become unstable later on. If you remain patient, the result will be clean and solid.
