ᐅ Which assembly screws are especially durable for IKEA Metod kitchen units?
Created on: 19 Jan 2023 14:07
tarba8
Hello everyone, I have a question regarding the installation of my new kitchen using the IKEA Metod system: Which assembly screws are particularly durable and recommended for ensuring the stability and longevity of the furniture? I understand that IKEA usually uses specific connectors and screws for their Metod cabinet units, but I would like to know if there are any experiences or recommendations on which screws (e.g., material, length, coating) are best suited for a long-lasting and secure installation. I am especially interested in how to prevent common weak points in the furniture, as I want to avoid later adjustments and problems. Thank you in advance for your opinions and tips!
PAREL
20 Jan 2023 15:45
To provide some clarity, here is a brief overview of durable screws suitable for IKEA Metod:
- Material: Zinc-plated (standard) or stainless steel (for damp areas, more durable)
- Diameter: 4 mm (0.16 inches) for stability in the cabinet panels
- Length: 40 mm (1.57 inches) standard, 50 mm (1.97 inches) for higher load or thicker panels
- Thread: Partial or full thread depending on the connection type; partial thread offers better hold in load-bearing joints
Common mistakes:
- Using screws that are too long – wood splitting
- Using screws that are too short – poor grip
- Using non-zinc-plated screws in damp areas – rusting
Tip: For doors and heavily loaded parts (e.g., drawers), special screws with larger heads and improved threading can be advantageous. For most Metod cabinets, inexpensive zinc-plated particle board screws are sufficient. Do not replace original connectors with standard screws, as this compromises fitting accuracy and stability.
juMira46
21 Jan 2023 08:14
tarba8 schrieb:
Which assembly screws are especially durable and recommended for IKEA Metod when it comes to the stability and longevity of the furniture?
I really appreciate that you’re thinking about long-term durability – that shows great foresight! 😊
I’ve had good experiences with stainless steel screws if you don’t want to use the original hardware. They are not only durable but also give a clean look, especially if you plan to assemble and disassemble the furniture multiple times. A small bonus: you can often feel the difference when screwing them in – they tend to go in more smoothly and break less frequently.
In conclusion: sometimes it’s worth spending a little extra time and investing in better screws. It saves hassle and repairs down the road.
