Hello everyone, I am planning to install several IKEA Platsa cabinets in my apartment but am unsure which mounting materials are best suited to ensure a stable and secure installation.
Perhaps there are some experiences or recommendations regarding which screws, anchors, or other fastening materials have proven particularly reliable, especially considering wall types (concrete, drywall, etc.) and the weight of the furniture.
Could you please explain in detail what to pay attention to and which mounting materials you would recommend to safely and permanently secure the Platsa cabinets? For example, I am also interested in tips on specific anchors or screws that work well without damaging the wall. Thank you in advance!
Thank you for the detailed answers.
To give you a better idea: my walls are mainly old concrete construction, partially covered with drywall (plasterboard) in other areas.
If I have these different wall types within the same apartment, would you recommend using different types of anchors during the installation of the Platsa cabinets depending on the location? For example, heavy-duty anchors for the concrete walls and cavity anchors for the drywall sections?
In practice, are there any issues when combining different fastening methods within one system? Or would it be better to stick to one type for aesthetic or safety reasons?
eminron schrieb:
If I have different wall types within the same apartment, would you recommend using different types of anchors when installing the PLATSA cabinets in the respective locations?Definitely yes, that actually makes sense. The fastening method needs to be adapted to the specific wall material. Use heavy-duty anchors for concrete, cavity anchors for drywall. The risk of using one type for all is that some anchors may not hold properly or could damage the wall.
eminron schrieb:
In practice, are there any problems when combining different fastening methods within one system?As long as all fastenings are installed correctly, it is not an issue. It is important that the loads are evenly distributed and all screws are tightened securely. Different anchors don’t affect the appearance since the anchors are inside the wall; only the screw heads are visible, and these are covered by the back panel of the furniture.
eminron schrieb:
If I have these different wall types within the same apartment, would you recommend using different types of anchors at the respective locations when installing the PLATSA cabinets?Yes, that would be the correct approach and the best solution. The wall and anchor must be compatible.
eminron schrieb:
In practice, are there any problems when combining different fastening methods within one system?No, as long as the installation is done professionally, it is not an issue. It is important that all screws are securely fixed and that load and weight are properly distributed.
Additionally: Since PLATSA includes several modular parts, it is worth using connecting hardware between the modules, such as metal brackets or screws, to prevent the entire system from becoming unstable later.
In summary:
- Use heavy-duty anchors with 6x60 mm (1/4x2 3/8 inch) screws for concrete walls.
- For drywall or plasterboard walls, cavity anchors or metal toggle anchors are recommended.
- Using different types of anchors within the same piece of furniture is acceptable and common, as long as the loads are distributed in a controlled manner.
- Additional connections between modules with metal brackets increase stability.
Recommendation: Be sure that all anchors are installed correctly; otherwise, durability may be compromised.
