ᐅ What installation mistakes should be avoided when assembling IKEA Metod kitchen units?
Created on: 13 Mar 2022 18:43
Jura59
Jura59
13 Mar 2022 18:43
Hello everyone, I’m interested in learning about common installation mistakes to definitely avoid with Ikea Metod kitchens. I have built several kitchens before, but with Metod, I notice that the cabinets have some specific characteristics, especially regarding alignment and stability. Specifically, I want to know if there are typical errors that frequently occur, such as incorrect screwing, imprecise alignment of the side panels, or incorrect mounting of the hinges, which can later cause problems. Maybe you can share from your experience what is particularly critical, so I can avoid these mistakes and end up with a stable, neatly assembled kitchen. Thanks in advance for your tips!
rigau
13 Mar 2022 18:57
It is important to assemble the side panels exactly at a right angle. Many make the mistake of roughly fitting the frames together, which results in crooked fronts. Also, make sure to loosen the screws properly if the holes do not align perfectly; otherwise, the material may splinter.
klo61
13 Mar 2022 19:16
Good evening! Regarding your question: Basically, I recommend following the assembly instructions for the Metod units carefully, as they are quite detailed. A common mistake is neglecting to secure the countertop, since it is usually installed at the very end. If the countertop is not properly fixed, the entire structure can become unstable. Aligning the cabinets accurately is also essential—imprecise work will make it harder to install the doors and drawers later on. Especially the hinges must be screwed in correctly to ensure the doors close properly; it’s worth using a square or level instead of relying solely on feel when screwing them in.
jordanvin
13 Mar 2022 19:48
Super important! Don’t forget to align the base rails correctly! I once installed them without paying close attention, and the cabinets ended up crooked. If you take your time and position everything properly, attaching the doors is really enjoyable! 🙂 Also, make sure to screw the removable wall brackets deeply into the wall anchors – safety first!
SUBEN60
14 Mar 2022 07:22
To prevent installation errors with Ikea Metod, I recommend strictly observing the following points: - Precise adherence to the angles and measurements when joining the carcasses. Inaccuracies can cause misalignment. - Proper fastening of the back panels, as they significantly affect stability. - Use the specified screws and fittings; do not replace them with similar ones, as they are specifically designed for the panel thickness. - Calibrate and adjust the hinges to avoid door misalignment. - Be careful when fitting the countertop to prevent damage. Mistakes here can lead to long-term issues.
nojaus
14 Mar 2022 09:17
One point I want to share from my own difficult experience: I had trouble installing the drawer fronts because I attached them too early, before the drawers were properly adjusted. This caused a lot of frustration and extra work. My advice is to patiently follow the instructions step by step and only attach the fronts once the internal mechanical components are correctly aligned.
