I am currently planning to assemble an IKEA Platsa cabinet system and have some experience with furniture assembly, but I still have certain uncertainties, especially regarding common mistakes that can occur during the assembly of Platsa.
Specifically, I am interested in: What are the most frequent assembly errors with IKEA Platsa that should definitely be avoided?
I’m not looking for general advice, but rather typical specific problem areas, for example with alignment, connecting the individual modules, wall mounting, and so on.
Who among you has experience with Platsa and can explain where errors typically happen? Are there fittings or screws that are often installed incorrectly, or common pitfalls that a beginner might easily overlook?
I look forward to your feedback and possibly tips that go beyond the standard instructions.
chenValeri13 Oct 2020 09:38It is common for the back walls to be improperly fitted. This leads to instability.
Wall fastenings are often forgotten or incorrectly installed, which should definitely be taken into account.
Hello sotugla,
Assembly errors with IKEA Platsa often occur for the following reasons:
- The connecting dowels and screws are not inserted properly or not tightened enough, which can affect stability.
- The connection between individual units is sometimes not aligned correctly, causing visible gaps and a crooked overall appearance.
- The back panel must be installed flush and square with the carcass, as it is crucial for stability. An uneven or tilted back panel will cause wobbling.
- The wall mounting is often underestimated, but it is essential for safety, especially with taller configurations.
I would also recommend checking each part carefully before assembly and following the instructions step by step, which prevents many mistakes. Sometimes a second person’s perspective helps to ensure everything is square.
If you like, I can share some tips on how to align the units optimally.
A common mistake I have noticed concerns the positioning and top view alignment of the anchor elements that contribute to stability. If these are not precisely aligned, tensions in the structure can develop, which may worsen over time.
Additionally, care should be taken to attach the wall fixings to a load-bearing surface. Drywall requires special anchors to ensure sufficient load capacity.
Another important point is the sequence when connecting the modules: it is recommended to loosely assemble and align the elements first, then fully fasten them to avoid any misalignment.
If information about the width of the modules is available, it is essential to use a spirit level and a tape measure, as this is the only way to ensure proper alignment later on.
Regarding installation errors with IKEA Platsa, it should be noted that the precision with which the panels fit together is often underestimated. Here are some details that frequently cause problems:
- Screws and dowels: Platsa modules use special fastening screws that should not be replaced with standard screws. Using screws of the wrong length can cause the material to split or compromise stability.
- Back panels: These are crucial for a torsion-resistant structure. If the back panels are only loosely attached or nailed in the wrong places, gaps will appear. Over time, this leads to wobbling.
- Edge protection and protective films: Sometimes adhesive films remain on sensitive surfaces, affecting the appearance.
- Incorrect alignment of modules: Platsa modules are often not installed flush, resulting in crooked lines and doors. This especially happens if the floor is uneven. Shims placed under the feet can help in such cases.
- Door installation: It is common for the door hinges to be incorrectly adjusted or for doors not to be aligned, even though IKEA provides adjustable hinges for this purpose.
Finally, it should be emphasized that wall mounting for Platsa should not be considered optional. It is worthwhile to check the wall condition in advance and use appropriate dowels if necessary.
It is also important to carefully follow the instructions during the initial assembly and avoid rushing to prevent mistakes.
PLOMA schrieb:
Screws and anchors: The Platsa modules use special fastening screws that should not be replaced with regular screws.That's correct. I once tried using a different screw, and the panel cracked. It's best to use the correct screws.
Also, it often happens that the back panel is not installed flush, which reduces stability.
