ᐅ What assembly mistakes are most common with the Ikea Brimnes series?
Created on: 27 Oct 2024 18:47
Ilirian
Ilirian
27 Oct 2024 18:47
I am currently working on assembling the Ikea Brimnes furniture system and have noticed that there seem to be some common assembly errors that frequently occur, negatively affecting both stability and functionality. Therefore, my question to you is: What assembly mistakes have you encountered most often with Ikea Brimnes, and what typical problems have resulted from them?
I am especially interested in errors that are repeatedly made during assembly, such as choosing the wrong screws, improper connections, or issues with aligning the components.
Are there perhaps systematic errors in the instructions that lead to these mistakes? Or specific steps where special attention is needed? I want to avoid these problems as much as possible from the start and would appreciate any experiences, including tips on how to prevent errors or how to fix them if they have already happened!
gasidney
27 Oct 2024 19:02
The most common mistakes are using the wrong screws in the holes and overtightening, which damages the material. Additionally, the back panel is often not secured properly, causing the shelf to become unstable later on.
Jensson
28 Oct 2024 11:37
Here is a summary of the most common mistakes made with Brimnes:
- Using the wrong screws: Ikea provides very similar screws that are easily confused. This often results in screws that are too short or too long, causing unstable connections.
- Not following the correct assembly sequence: Sometimes a part is fully assembled before smaller components or shelves are installed. This makes adjustments difficult and can damage the drill holes.
- Incorrect installation of the back panel: The thin back panel is crucial for stability. Many only secure it with a few nails, which makes the furniture wobbly.
- Not checking the alignment of the fronts: Doors and drawers in Brimnes need precise adjustment; otherwise, they won’t close properly or may rub.
My tip: Follow the instructions carefully, step by step, and sort all parts before assembly. Work gently with the screwdriver and avoid overtightening the screws.
gasidney schrieb:
The most common mistakes are wrong screws in the holes and overtightening, which damages the material.
Yes, I agree completely, which is why I strongly recommend checking the screws before assembly.
Filippo
29 Oct 2024 09:15
I would like to take a closer look at the common problem areas typical for the Ikea Brimnes:
1. Screws and fasteners:
Brimnes uses a variety of identical fasteners, distinguishing between elongated hole screws, wood screws, and large dowels. A common mistake is using elongated hole screws in the wrong place, for example where a wood screw is intended. This reduces the tensile strength.
2. Pre-drilling and material settling:
The particleboard panels of the Brimnes system are sensitive to excessive torque, so gentle screw insertion is necessary. Otherwise, the material may crack or screws may not hold firmly. This is especially important for load-bearing components, such as side panels.
3. Installing the back panel:
The back panel is often installed last, but it is crucial for drawer guidance and overall stability. It frequently is not flush or is installed crookedly, which can have serious consequences for the entire construction.
4. Adjustment of drawers and doors:
Uneven floors or improperly screwed hinges cause doors not to close properly or drawers to be difficult to open. Precise alignment through screws and testing in several steps is required.
5. Complexity of the instructions:
The manual is sometimes designed so that follow-up tasks are not clearly explained at times—for example, adjustment screws that can only be accessed after complete assembly. This can lead to screws being stripped when tightened too much in the wrong places.
My question: Have you checked whether your version of the furniture is affected? Brimnes comes in different configurations, which can influence susceptibility to these problems.
blapau
29 Oct 2024 19:44
A common mistake that is often underestimated is poor preparation of the work surface. If installation takes place on an uneven or excessively hard floor, components can warp or be misaligned. This mainly affects the functionality of drawers and doors.
I also recommend counting and sorting the supplied screws and nails before assembly. This way, you can almost immediately identify if any replacements or shortages are needed, which often causes problems during later construction.
Filippo schrieb:
The particleboard panels of the Brimnes system are sensitive to excessive torque, so gentle screwing is necessary.
I can confirm this; careful work with a cordless screwdriver that has a torque setting provides clear advantages and prevents consequential damage.
In summary, I advise taking your time, preparing your tools, and reviewing the instructions step by step, especially paying attention to warnings regarding component alignment.
