ᐅ Which areas of the bathroom should be tiled?
Created on: 29 Apr 2020 10:03
neutri80
Hello dear forum,
We have been thinking for weeks about which areas in the bathroom should be tiled but can’t find a solution. That’s why we are hoping for your help.
We want to tile as little as possible, but we have the problem that there is a window on the wall opposite the shower, and we don’t know how to tile around it without it looking awkward. Also, we are unsure how to tile around the bathtub. And for the wall under the large window in general, should we plaster it, tile halfway up, or something else? We just aren’t creative enough here.
At the washbasin, we would like to tile only halfway up, and behind the toilet, we want to tile just the wall behind it, also halfway up.
We would really appreciate any tips.
Ivonne
Grundriss eines Zimmers mit Bad: grün markierte U?Theke, Badewanne, zwei Kreise, Pfeile.
Alessandro
29 Apr 2020 13:00
I don’t understand the black towels @Climbee. They draw too much attention, appearing like black holes against the white furniture and white walls. Otherwise, I like the bathroom.
What I really don’t like at all is the typical German toilet in the main bathroom. I’ll never understand it, but I don’t have to.
saralina87
29 Apr 2020 13:11
Alessandro schrieb:
What I really don’t like at all is the typical German toilet layout in the main bathroom.
I will never understand it, but I don’t have to.
I once had a friend whose shower and toilet were in separate rooms. I can’t even remember how many times I had to run naked from one room to the other because I needed to use the toilet again after I was already undressed...
No, no, no. It must all be in one place.
Alessandro
29 Apr 2020 13:15
That is purely a matter of habit. Normally, you go to the toilet first before undressing in the main bathroom to take a shower.
Even if you occasionally run naked through the hallway, so what? Who would be bothered by that?
I know a thousand arguments against having a toilet in the main bathroom, but apart from the (minor) additional costs, not a single reason in favor.
That’s why I have been wondering for years why this is still the case.
Altai
29 Apr 2020 14:46
@Climbee compliments from me as well! If it weren’t for a few personal items visible, you might think this came straight from a promotional brochure!
I only wanted tiles where necessary. On one side, the bathtub and toilet are next to each other (separated by a small partition wall). Since there is a sloping ceiling here, that determined the height. We applied the same height on the opposite side at the washbasin. Otherwise, the tiles around the toilet extend to the same depth as the bathtub, going around the corner. And, of course, the shower walls are fully tiled up to the ceiling.
You just have to think about where it might get wet—and up to what height. That defines the tiling areas.
Choosing the tiles is a challenge on its own. I couldn’t imagine how it would look in the bathroom. Fortunately, the result had a real “wow” effect. If you’re unsure, the only option is to consult a professional who can create a 3D visualization.
Climbee29 Apr 2020 14:47
Katdreas schrieb:
OMG, this isn’t a bathroom, it’s a wellness sanctuary! Very beautiful.
Yes, we like it too – but it’s funny that it was basically a “byproduct” that just turned out quite well. We had these factors to consider:
1. A bedroom that can fit a large bed
2. A staircase
3. A utility room on the upper floor
4. A gallery
and the leftover space became the bathroom. It also developed a bit during construction, but considering the fragmented room layout, it ended up quite good.
Alessandro: for the longer sessions, we have a toilet on the ground floor. Upstairs is only for quick use and at night. Otherwise, we’re usually down there anyway. We’re very relaxed about it and don’t mind if one person is using the toilet while another is brushing their teeth at the washbasin.
And just last week, I was standing in the shower and realized I still had the tampon in… then would I rush, dripping wet, to another room to get into a state suitable for using a tampon-free shower? No thanks… No, it’s fine just as it is. I wouldn’t want it any other way.
I currently like the dark gray (not black!!!!) towels. It might be that I’ll go through another green or red phase again, and then the towels will change. I like white towels, but they’re tricky since the shade doesn’t always match the furniture, and after a few washes most of them unfortunately turn a bit gray. I don’t find that very appealing.
neutri80
29 Apr 2020 15:04
Alessandro schrieb:
I assume you haven’t planned a door for the shower, right?
I would definitely tile the wall behind the washbasin all the way to the ceiling as a feature.
As long as you’re careful when bathing, you don’t necessarily need tiles on that wall. If it gets wet occasionally, it will dry again, and generally people bathe less often than they shower.
In the shower, I would tile the wall at the top plan up to the height of the T-piece. Also, I would install a towel rail or radiator on the small wall next to the window at the top plan.
I am really overwhelmed by all your replies—thank you very much in advance.
Yes, we do not have a door planned for the shower.
If we don’t tile around the bathtub, will the fittings be flush-mounted in the wall? Is that possible?
The idea of a rod for a towel is very good.
