ᐅ What alternative screw systems can be used for IKEA PLATSA?
Created on: 17 May 2024 14:03
bentley47
I am currently planning an expansion of my IKEA Platsa system and am looking for alternative screw systems that work better than the original connectors or, for example, allow for a more stable or flexible installation.
Specifically, I am interested in which types of screws you have used to make the connection points more robust or possibly faster to assemble. Are there any special screws or connection solutions that have proven particularly effective without compromising the appearance or modularity?
Maybe also tips on diameters, lengths, or thread types that better fit the drilled holes and materials (mainly chipboard and MDF used in Platsa)?
I look forward to practical experiences and recommendations, including advice on what to avoid.
bentley47
18 May 2024 10:28
LOGEMIN schrieb:
A common mistake is using screws that are too short, providing little hold, or too long, which can damage the material. Also, it is best to avoid Phillips screws, as they tend to strip quickly.
This matches my experience. Areas under high stress often suffer from pull-outs when using cheap screws or incorrect lengths.
I am curious if anyone here has experience with stainless steel screws or galvanized versions? What advantages and disadvantages have you noticed, particularly regarding durability and material compatibility?
Also: Are there special fine-thread screws that are better suited for MDF?
Jukin
18 May 2024 11:37
Hello bentley47,
Regarding your question about stainless steel screws: These screws definitely offer higher corrosion resistance, which is especially beneficial in more humid environments. However, in normally dry indoor areas, they are usually not absolutely necessary.
For MDF, fine-thread screws are advantageous because they provide better grip and cause less swelling or tearing of the material. For Platsa, I like to use
- stainless steel A2 screws with fine threads, 4x40mm (approx. 5/32 x 1 9/16 inches)
- in combination with special hardwood screws or SPAX screws
This results in a durable, strong connection.
bentley47 schrieb:
Mich würde interessieren, ob jemand hier Erfahrung mit Schrauben aus rostfreiem Stahl oder verzinkten Versionen hat?
I recommend stainless steel if you want long-term durability without squeaking and rust stains on the wood.
benon
19 May 2024 08:22
I would also like to briefly address the selection of screws for IKEA PLATSA. In addition to the mentioned options, using cam lock screws can be a good idea. These screws and connectors are typical for furniture and allow for a stable, reversible connection.
Specifically:
- Replace the original cam locks of the PLATSA system with ones that have a larger diameter and stronger tooth engagement.
- This increases stability and expands repair and modification possibilities.
Another alternative is pan head screws with a Torx drive. Their flatter shape is visually appealing and makes assembly with cordless screwdrivers much more comfortable.
Caution:
- Always adjust to the material thickness and pre-drill to avoid damaging the workpiece.
Conclusion: Depending on whether stability, appearance, or assembly speed is more important to you, different types of screws can be used to enhance the PLATSA system effectively.
