ᐅ What alternative materials can be used for IKEA Besta fronts?
Created on: 4 Feb 2024 10:07
garrit
I am currently working on a renovation project and planning to replace the fronts of IKEA Besta cabinets myself using alternative materials. My question is: which materials have proven successful for you as replacement fronts for IKEA Besta, and are manageable in terms of cutting, fastening, and surface finishing?
I am particularly interested in materials that offer high durability for everyday use, as well as those that can add a unique visual touch without becoming too complicated or expensive. I look forward to any advice on material selection, sources, and processing details such as adhesives, screws, or surface treatments.
Thanks in advance for sharing your experiences!
Dopoki
5 Feb 2024 14:31
garrit schrieb:
I am specifically interested in which adhesives are suitable when attaching fronts to existing Besta doors (so not completely new fronts, but front medley). Are there recommendations for particularly strong, durable adhesives that do not damage the surface or cause deformation? Or are screws and adapters really the better solution?
For attaching fronts to existing doors, the use of double-sided mounting tape (e.g., from 3M) with high load capacity is generally recommended. This prevents surface damage and localized deformation better than liquid adhesives, which may absorb moisture or create pressure marks depending on the substrate.
Liquid adhesives such as PU glue can cause swelling on MDF and should be avoided if the material is sensitive.
Regarding thin plywood panels (approximately 9 mm (0.35 inches)), caution is advised with standard Besta hinge systems: the reduced thickness can lead to stability issues and insufficient hinge support. In such cases, backing plates or adapter solutions may be necessary to ensure secure fastening.
JORDON
6 Feb 2024 08:58
noge58 schrieb:
I would recommend considering plexiglass or acrylic glass if you want something a bit more personalized.
I think using plexiglass is really cool! 😎 Especially if you want something modern and slightly futuristic that really stands out.
For a small project, I tried acrylic glass panels covered with frosted film – it definitely created a wow effect and was easy to work with. Gluing plexiglass isn’t always ideal; small screws or suitable clips work better.
Another interesting option could be white painted aluminum panels for the front if you want something durable and distinctive. They are simple, fairly thin, and look very high quality (of course, a bit more expensive, but hey – quality often pays off 😉).
