ᐅ What alternative materials can be used for IKEA Besta fronts?
Created on: 4 Feb 2024 10:07
garrit
garrit
4 Feb 2024 10:07
I am currently working on a renovation project and planning to replace the fronts of IKEA Besta cabinets myself using alternative materials. My question is: which materials have proven successful for you as replacement fronts for IKEA Besta, and are manageable in terms of cutting, fastening, and surface finishing?
I am particularly interested in materials that offer high durability for everyday use, as well as those that can add a unique visual touch without becoming too complicated or expensive. I look forward to any advice on material selection, sources, and processing details such as adhesives, screws, or surface treatments.
Thanks in advance for sharing your experiences!
pikin
4 Feb 2024 10:45
As an alternative to IKEA Besta fronts, various materials are suitable that are easy to work with and durable:
- MDF boards: Especially popular because they have a very smooth surface and can be painted or laminated in many ways. Typically 16 mm (5/8 inches) thick, which fits well with Besta mounting.
- Plywood: Lightweight, sturdy, and with attractive grain patterns, especially when clear coated.
- HPL boards (High Pressure Laminate): Very resistant to scratches and moisture, expensive but stable in the long term.
- Real wood veneer on MDF: For a premium look, but requires experience when gluing.
For mounting, I recommend multiplex adapter plates or doubled MDF back panels, as many of the original mounting points follow standard dimensions. Glue is only recommended to a limited extent; screws or original IKEA adapters usually work better.
Avoid materials with a high tendency to deform or boards that are too thin, as fronts can sag otherwise.
noge58
4 Feb 2024 12:13
Wow, this topic is really exciting! 😊 Last week, I replaced my Besta fronts with thin plywood panels, which I then covered with a beautiful veneer and clear varnish. The result turned out fantastic—no laminate can ever look like that!
If you want something a bit more unique, I’d recommend considering plexiglass or acrylic glass. It’s a bit more DIY, but it’s a real eye-catcher and very durable. You can also combine it nicely with LED backlighting to give your shelves a special touch!
Good luck, this is a really great project!
pikin
4 Feb 2024 13:38
noge58 schrieb:
I would recommend considering Plexiglas or acrylic glass if you want something a bit more custom.
That’s a good point. Plexiglas is easy to cut and drill, but it is more prone to scratches than HPL or MDF. It needs to be securely fixed since it can bend under stress. Additionally, UV-resistant versions should be chosen if the panels are exposed to a lot of sunlight.
For applications with higher demands, traditional engineered wood materials are indeed the more durable choice. However, for those who really want to emphasize the look and go for a unique style, acrylic is an option.
fredle
5 Feb 2024 09:16
I would like to add a brief guide to help with remodeling using alternative fronts for IKEA Besta:
1. Material selection: MDF with a minimum thickness of 16 mm (5/8 inch) is the standard, as the fastening holes are designed for this thickness.
2. Cutting: Make sure the edges are clean – with MDF, always prime the cut edges to prevent moisture absorption.
3. Fastening: Original Besta fittings usually only fit 16 mm (5/8 inch) thick fronts. For thicker fronts, use additional adapter strips or special screws with longer threads.
4. Surface: Acrylic or PU paints are best for coatings, as they are durable. Laminating is a good alternative; here, high-quality foils should be used.
5. Tip: Before final installation, always pre-drill all holes and use countersunk screws to avoid damaging the material.
Common mistakes include bonding without considering material thickness and failing to pre-drill MDF, which can cause cracks.
I hope this helps!
garrit
5 Feb 2024 10:42
fredle schrieb:
Common mistakes include gluing without considering the material thickness and failing to pre-drill MDF, which can cause cracks.
Thanks, that’s very helpful! I’m particularly interested in which adhesives are suitable for attaching fronts to existing Besta doors (so not completely new fronts, but front overlays). Are there recommendations for especially strong, durable adhesives that don’t damage the surface or cause warping? Or are screws and mounting brackets really the better solution?
Also: Has anyone had experience with thinner plywood sheets (e.g. 9mm (0.35 inches)) as front replacements? Are these accepted, or do they cause problems with stability or hinge installation?
