ᐅ Which alternative fittings are compatible with IKEA Hemnes?
Created on: 14 Apr 2024 08:32
klofevzi63
klofevzi63
14 Apr 2024 08:32
I am currently facing the challenge of changing the hardware on my IKEA Hemnes furniture. I am looking for alternative hardware that is both visually appealing and functional for the Hemnes series. Specifically, I am interested in handles or knobs that can be installed easily, without requiring complex drilling or modifications to the doors. Compatibility in terms of drilling holes and load capacity is also very important to me, as the furniture is used frequently.
Perhaps someone here has experience with alternative hardware and can recommend products or brands that work well with IKEA Hemnes. Are there any particular details about hole dimensions or preferred materials I should be aware of?
I am very much looking forward to your tips and recommendations – explanations on why they are a good fit are also welcome! Thank you in advance.
Elijah42
14 Apr 2024 09:15
I would recommend looking for fittings with standard 32 mm hole spacing, as these usually fit well. Many people use simple metal handles or round knobs made of brass or stainless steel, which are easy to screw on. Just make sure the screw length matches the door thickness.
todunar
14 Apr 2024 11:03
Hello klofevzi63, great project! 😊 Vintage or retro handles are very trendy for Hemnes furniture – they add a nice accent to the classic style. I’ve personally upgraded old furniture with these kinds of handles, and it’s really fun! You don’t need to make major adjustments during installation, as the standard drill holes usually fit perfectly. So go for it, the variety of designs is huge, and you’re sure to find something nice and suitable!
U
uslis47
15 Apr 2024 14:27
I would like to add that the doors in the IKEA Hemnes series typically have a hole spacing of 64 mm (2.5 inches) for the handles, which is somewhat unusual compared to the standard 32 mm (1.25 inches) spacing found on many other pieces of furniture.
Therefore, it is important to look for handles or knobs that are compatible with this hole spacing, or alternatively to use adjustable fittings that can accommodate different drilling distances.
In terms of materials, I recommend wooden handles or matte brushed metal finishes for Hemnes, to emphasize the typical Scandinavian style.
If someone wants to enlarge or double the existing holes: that is possible, but be cautious about the door’s stability, as the chipboard surface can be quite delicate.
I hope this helps a bit.
Dopoki
16 Apr 2024 19:53
In summary, I recommend:
- Checking the exact hole spacing (often 64 mm (2.5 inches) for Hemnes, not 32 mm (1.25 inches)!).
- Choosing handles with the appropriate screw length, as the door thickness is approximately 18 mm (0.7 inches).
- Materials such as brushed stainless steel, wood, or brass are suitable options for durability and style.
- If the hole spacing does not match, consider flexible mounting options or drilling new holes, taking care to avoid damaging the door.
Researching garden or building supply stores might also help find brands with compatible measurements.
Please note that IKEA often supplies handles with concealed screw fastenings, which may not be the case for replacement handles.
