ᐅ What alternative fasteners are suitable for Ikea Brimnes furniture?
Created on: 31 Oct 2021 09:23
sonko
sonko
31 Oct 2021 09:23
I am currently looking into mounting options for Ikea Brimnes furniture. In particular, I have found that the original fixing materials are sometimes not ideal, especially when it comes to stability and safety in everyday use, such as with shelves or beds. Therefore, I would like to ask: which alternative mounting solutions are truly reliable and suitable for Ikea Brimnes furniture? I am especially interested in which fastening methods or materials can effectively complement or replace the standard solutions without compromising the appearance or functionality.
Any experiences or tips on what to watch for when replacing or supplementing the fixings—such as material thickness, wall type, or load capacity—are very welcome. I look forward to constructive answers and a professional exchange of experiences!
Leland
31 Oct 2021 10:05
For Brimnes, I recommend using additional metal brackets for wall mounting. Simply attach them to the back of the furniture frames and then securely fix them to the wall. This prevents the risk of tipping and significantly increases stability.
Siflo
1 Nov 2021 14:17
Regarding alternative mounting options for the Ikea Brimnes, I recommend using a combination of screws with suitable wall anchors and metal brackets. The original wall fittings from Ikea are often designed for standard walls but may not be sufficient for all wall types.
- For concrete or brick walls: Use high-quality heavy-duty anchors (e.g., expansion anchors or impact anchors).
- For drywall (plasterboard) walls: Use specialized drywall anchors to safely support the weight.
- Metal brackets (approximately 30x30 mm (1.2x1.2 inches)) enhance stability and prevent deformation.
It is important to check the wall’s load-bearing capacity before installation and choose the appropriate anchors accordingly. This ensures a secure and durable mounting without damaging the furniture.
theo63
2 Nov 2021 11:42
Siflo schrieb:
The original wall mounts from Ikea are often designed for standard walls but are not always sufficient for all wall types.
I consider this assessment very important. I would add that many users tend to overestimate the load capacity of the original mounts, especially with Brimnes, which is often used as a room divider or storage shelf.
Are alternative fastenings with metal brackets alongside the wall mounts always the best solution? In some cases, I have also used so-called heavy-duty anchors, which can support multiple times the weight. It is, of course, crucial to adjust the size of the plugs and screws to the wall material and not to rely blindly on standard solutions.
