ᐅ When should you replace Malm furniture instead of repairing it?
Created on: 14 Mar 2015 08:42
Mafaju
I am currently wondering when it makes more sense to replace an IKEA Malm piece of furniture rather than repair it. Specifically, I have a dresser where some drawers no longer slide properly, one corner is damaged, and the surface is showing initial signs of wear.
I would be interested to know when you consider the critical point is reached where repairing no longer makes sense. Should the lifespan of the material be taken into account? What level of effort and cost do you consider the limit? And are there typical types of damage where you would immediately recommend buying new?
I look forward to your opinions and experiences!
Parmin
14 Mar 2015 12:18
I wonder if it also matters how much one values the character of their own furniture.
Mafaju schrieb:
a dresser with several drawers that no longer slide properly, a damaged corner, and a surface showing initial signs of wear
It is often underestimated that early surface and corner damage are not just cosmetic flaws but can also weaken the stability.
Wouldn't it be wise to consult a carpenter or similar professional before making a final decision? Or to have them provide a rough estimate of repair costs? This often reveals possibilities that might not be obvious otherwise.
Mafaju
14 Mar 2015 12:57
Thank you for your previous assessments!
@Parmin, I like the idea of consulting a carpenter, but with such inexpensive furniture, it is often not cost-effective – the consultation fees might end up being higher than the potential repair costs.
@GLORIA has compiled many important facts well. The material properties and common types of damage are important reference points for me.
I am also concerned about how sustainable replacement is compared to repair. In other words, can a well-done repair actually provide longer enjoyment of the furniture? Or does the low quality of Malm furniture tend to reduce its value in this regard?
So I wonder: where do you draw the line between "technically still repairable" and "economically reasonable to replace"?
pintra
14 Mar 2015 13:39
It’s great to see this topic is so active! 🙂 For me, the Malm is more of a temporary piece of furniture — sturdy enough to last a few years but not built to last forever.
GLORIA schrieb:
Replacement makes sense when ... the time investment becomes too high
I agree with that. Sometimes repairing just isn’t enjoyable anymore because you’re always struggling with tape and screws 😉
So if you notice your dresser is turning more into a project than a practical helper, it’s better to replace it. And hey, assembling a new one can be fun too, I think! 😉
Lisele
15 Mar 2015 08:46
I also want to add: For me, the frequency of use is crucial. If I use the piece of furniture every day and it is constantly a source of frustration, then I cannot recommend endlessly repairing it.
Mafaju schrieb:
Where do you draw the line between "technically still repairable" and "economically sensible to replace"?
The emotional factor often plays a role here: Sometimes people hold on to furniture out of sentimentality, even when it is gradually failing. But life shouldn’t be more complicated than necessary! When the frustration outweighs, I replace it.
Henry
15 Mar 2015 10:03
Sometimes I feel exactly like Lisele.
I value long-term use and sustainability, but especially with cheaper furniture, you sometimes spend more energy repairing it than the time and enjoyment you gain.
Maybe a better option would be to consider a quality upgrade – basically an enhancement through custom modifications or retrofitting with better runners?
However, I’m unsure if that is really worthwhile for Malm. Does anyone have experience with such modifications?
dachen
15 Mar 2015 11:35
Interesting point, Henry.
If we approach the discussion systematically, there are several levels:
1. Pure functionality
2. Aesthetics
3. Sustainability
Henry schrieb:
eine qualitative Aufwertung nachzudenken
However, this reveals the limitation that the basic construction of the Malm furniture from particleboard restricts durability at its core – no matter how much you improve the surface or the hardware.
It would be interesting to know if anyone has reliable long-term experience with such upgrades and whether they are truly cost-effective compared to purchasing higher-quality new furniture.
