ᐅ Site development timing: Before building road construction or after debris removal?
Created on: 23 Jul 2020 06:59
Spike86
Good morning
Last week, we submitted the building permit application (as an expedited process, since there is no zoning plan). Now we are considering whether it makes sense or is even possible to connect the utilities before starting construction. The problem is that we have a flag lot, and the driveway runs to the back through the neighbor’s property. Once the construction road is set up, access to the utilities will be blocked, and we would only be able to connect them after construction is completed and the construction road is removed... wouldn’t that be too late? Isn’t a water connection needed beforehand so the plumbing contractor can test the toilet flushing? We are a bit unsure about this. Another issue is that the neighbor’s house is very close to the driveway and has a full basement. Therefore, part of the construction road would need to be reinforced. Do you have any tips on how to do this or if it is necessary? A friend once recommended these mats that distribute the weight. With these, an 11-ton (12 US ton) excavator (loaded up to 16 tons / 17.6 US tons) was able to pass without causing any damage.
It’s early in the morning, so I hope this is clear enough. If not, please ask, and I will try to explain it better.
Best regards and thanks in advance!
Technischer Bauplan/Site-Plan mit Straßenverlauf, Gebäuden, Zahnradsymbol und Beschriftungen.
Nida35a20 Sep 2020 18:36
Garden faucet with a 1/2 inch hose 20m (65.6 ft) and garden sprayer; no one complained, and everyone dutifully collected their water.
Since family is free,
a stranger would receive a banknote and a drink from me.
Spike86
20 Sep 2020 18:40
Thanks for the quick response! The strange thing is that the construction company insists on 4 bar pressure?! I’m not sure if that’s common oO
Otherwise, I would also say just use the water from the outdoor tap and that’s fine.
PS: It’s really annoying that you can’t send private messages, honestly.
K1300S20 Sep 2020 18:42
4 bar is the typical pressure in a single-family home. Otherwise, it just takes longer.
Nida35a20 Sep 2020 18:46
Which construction tool doesn’t work at 2 bar pressure? Most of the time, the nozzle was removed and the bare hose was used to fill buckets or held directly into the mixing container for adhesive, mortar, etc.
Nida35a20 Sep 2020 18:49
Drilling rig or drilling device for water source heat pump?
Spike86
20 Sep 2020 18:55
Most of the time, the sprayer was disconnected, and the bare hose was used to fill buckets or held directly in the mixing container for adhesive, mortar, etc.
Exactly, it’s made to seem like a big deal... the construction specification states "...water supply (4 bar)."
