ᐅ At what point does the KALLAX become critically unstable when fully loaded?
Created on: 15 Jul 2023 08:37
LULEDIHello everyone,
I am currently looking into the question: “At what point does the KALLAX shelving unit become critically unstable under full load?” Specifically, I am interested in the maximum total load and the particular conditions under which the shelf starts to lose its stability or shows permanent deformation, so that it risks tipping over or sustaining damage.
I’m not only concerned with the nominal load capacity per shelf board but also factors like the type of loading (bottom-heavy, evenly distributed, or top-heavy), the number of installed shelves, anchoring behavior, and whether the unit is placed on uneven flooring.
Are there reliable guidelines or practical experience that indicate tipping points or critical load limits? I would appreciate any expertise on this topic – including structural details or practical advice. Thank you very much!
To begin with, the IKEA KALLAX shelf is officially rated for a maximum of 13 kg per shelf board. This means the total maximum load is approximately 52 kg for a unit with four shelves—assuming an even weight distribution.
However, the issue of stability is more complex: critical instability mainly occurs when the load is too heavy and/or the center of gravity is too high or unevenly distributed. Placing heavy items only on the upper shelves significantly increases the risk of tipping.
The shelf itself does not have built-in anchoring, which is a major weakness: when fully loaded and with a higher center of gravity, it can be prone to tipping, especially on smooth or uneven floors.
A tip: adding wall attachment significantly reduces the risk of tipping and often allows for a slightly higher load capacity. So, if you want to be on the safe side, I would recommend always securing the KALLAX to the wall and storing heavy items in the lower shelves.
I hope this helps as an initial assessment.
Blavin schrieb:
Critical instability mainly occurs when either the load is too high and/or the center of gravity is too high or unfavorably distributed.This is exactly the key point I want to elaborate on: The KALLAX is a piece of furniture with comparatively low own weight and a height of 77 cm (30 inches) in the standard version, which significantly influences the leverage effect when the center of gravity shifts.
To determine the stability limit, we should consider the following:
1. Load distribution: If the load is concentrated in the lower two compartments, the center of gravity remains low and the risk of tipping is minimal. However, placing a heavy load in the top compartment increases the tipping moment.
2. Total weight: At 13 kg (29 lbs) per shelf, you reach about 52 kg (115 lbs) for four compartments – this is the maximum load capacity according to the manufacturer. Exceeding this (e.g., by loading heavy binders, tons of books, etc.) increases the risk of shelf deformation and especially puts more stress on the frame.
3. Floor conditions: On uneven floors without appropriate feet protection (such as felt pads), the shelving unit can tip easily.
4. Anchoring: Without wall fixation, there is a significant risk, especially when the unit is loaded and moved.
Regarding critical instability: Technically, this begins when the tipping moment acting on the shelving from external forces or load distribution exceeds the counterweight of the shelving unit itself.
Practically speaking: With more than 40 kg (88 lbs) total load combined with poor center-of-gravity placement and without wall anchoring, the risk of tipping increases significantly. Higher loads (> 60 kg (132 lbs)) quickly exceed the structural integrity of the shelves.
Therefore, my recommendation: For complete safety, the total load should remain under 50 kg (110 lbs), distributed as low as possible, and secured with wall anchoring!
Wow, such interesting insights here! 🙂 This means that the KALLAX is not only about the maximum load per shelf but really depends on how the weight is distributed and whether the shelf is secured to the wall – very important!
I’ve had the KALLAX for years and store quite a few books in it – heavier ones mostly at the bottom and lighter ones on top. So far, it has held up well, but there was a moment when I thought it might tip over because I placed a few larger items on the upper shelves.
This definitely motivates me to check if I have secured the shelf properly.
Thanks for the tips – who would have thought that such an everyday piece of furniture could actually be a small structural engineering project! 😉
One more question from me: Are there any recommendations on the best fixing materials to secure the KALLAX to the wall? Corner brackets, screws with wall plugs, or something else?
