ᐅ When are MALM dressers too damaged to be repaired?
Created on: 25 Sep 2017 20:37
Ennoni
Ennoni
25 Sep 2017 20:37
I would like to start a discussion because I am currently wondering: At what point are Malm dressers from the IKEA range so badly damaged that repairing them no longer makes sense from a technical and economic perspective?
I am particularly interested in specific criteria or types of damage where you have reached the point that it is better to consider a replacement or at least a major part swap. Especially with MALM dressers, which are quite common, there are often minor damages but also severe issues, such as broken side panels, warped drawer slides, or split bottom boards.
I am curious about your experiences with the materials, durability, and extent of damage. How do you set your limits when it comes to repairs? My goal is to get an understanding that clearly shows where the boundaries of DIY repair lie and when it no longer makes economic sense to intervene manually.
Thank you for your opinions and tips—I look forward to your contributions!
Fredlo
25 Sep 2017 21:12
Oh, this is a great topic! 🙂 I’m a big fan of DIY repairs on MALM dressers because the parts are generally very compatible and easy to take apart.
In my opinion, the limit is reached when, for example, the load-bearing side panels are completely broken or when the drawer slides are warped and can no longer be properly adjusted. Especially the material—often particleboard with a veneer—tends to be so badly damaged in these cases that a permanent repair would require a lot of effort and special glue.
But: Small damages, like peeling veneer, minor cracks, or drawers that don’t slide smoothly anymore, are easy to fix in my experience! A bit of sanding, glue, and then it works smoothly again! So don’t give up right away, it’s really great to tackle this! 🙂
Looking forward to more opinions on this—this topic definitely has potential!
dinano
26 Sep 2017 07:28
Fredlo schrieb:
In my opinion, the limit is reached when, for example, the load-bearing side panels are completely broken or when the drawer slides are warped[...]
I think this is an important point, but it should be considered more nuanced. The "load-bearing side panels" of a MALM are not solid wood but usually made of engineered wood with a foil coating. This means that while a break compromises stability, often repairs are still possible through reinforcement or replacing a side panel.
However, it must be taken into account that cost-effectiveness strongly depends on the time required, material costs (replacement parts), and one’s own skills.
Ennoni schrieb:
How do you set your limits when it comes to repairs? I’m looking for an assessment that clarifies where the boundaries of DIY capabilities lie and when professional intervention is no longer economically sensible.
Here, I would recommend categorizing specific damages into (minor, moderate, severe) and then comparing professional repair costs with the price of replacement. This provides clarity. Otherwise, much remains subjective.
What are your thoughts on this?
Guyju
27 Sep 2017 10:54
Good morning everyone,
I would like to organize the discussion a bit by categorizing possible damage cases for MALM dressers and briefly explaining when a repair is still worthwhile and when a replacement is recommended.
1. Surface damage (scratches, small dents, chipped veneer): In these cases, repair is definitely worthwhile, for example using wood filler, sandpaper, and color-matched paint or foil. Cost: low, effort: moderate.
2. Problematic damage to drawer slides: If the slides stick but are not severely deformed, they can often be cleaned, lubricated, or replaced with spare slides. Be careful with warped side panels, as this can be more difficult to fix.
3. Broken side panels or back panels: This is clearly a case where repairs require significant effort and often have uncertain success. Particleboard tends to absorb moisture when broken, which reduces stability. In such cases, getting a new piece of furniture is usually more cost-effective and sustainable.
4. Water damage: It depends on the affected areas. Small spots with swelling can be treated locally, but large-scale damage usually cannot be repaired effectively.
Conclusion: Repair is worthwhile for small to medium damage, especially to preserve functionality. Larger structural damage often leads to the need for replacement.
I hope this helps with your assessment! If you need specific repair tips, I’m happy to assist :-)
