I am aware of the principle that with copper piping for heating systems (which should be the standard), an expansion joint must be installed every 10 m (33 feet) of pipe length. That sounds logical and I have seen it done before. My question is: Is there a standard, manufacturer’s guideline, or similar regulation that requires this? In other words, is it recommended practice or a mandatory rule? I would appreciate knowledgeable answers.
This is also not a problem in the heating sector because there is no pitting corrosion due to the almost complete lack of oxygen in the water.
If the water pipes are going to be renovated anyway, I would completely remove them. In this process, you can of course also replace the heating pipes and have everything new.
I don’t know anyone nowadays who still installs copper pipes under plaster or screed. Leaks practically no longer occur with plastic pipes.
The crucial question was about the expansion of copper pipes when installed exposed on the surface.
Deliverer4 Mar 2020 09:10hegi___ schrieb:
I don’t know anyone nowadays who still installs copper pipes under plaster or screed. Leakages practically don’t occur anymore with plastic pipes. Now you know one. In two weeks, new 35mm (1.4 inch) copper pipes will be installed as supply and return lines to the heating circuit distributors.
So what now? It seems like no one knows any regulations or rules?
