ᐅ What user experiences are there with assembling the Ikea Brimnes?
Created on: 20 Oct 2024 08:17
laelge
Hello everyone, I am planning to assemble the Ikea Brimnes bed frame soon and wanted to ask about your experiences: Has anyone had the chance to put together the Brimnes bed before? I am particularly interested in practical tips for assembly, potential pitfalls, and advice regarding the included tools and materials. Since the assembly instructions can sometimes be a bit unclear, I would like to know in advance if there are any specific sections or steps to pay extra attention to, especially regarding stability and safety. Thanks in advance for your feedback!
The Brimnes is such a classic – I assembled it last year and actually found it quite straightforward. ? My tip: Play some music in the background and take your time with each step, especially when tightening the screws. Less is more – don’t apply too much force at once. And yes, it’s definitely more fun and faster with two people! In general, no need to panic, this thing is quite durable.
I wanted to add that properly assembling the back panel is really crucial for the stability. If it is not installed correctly, the bed can quickly become warped. I also recommend using the assembly tools included in the package and not improvising, as the screws have different sizes and profiles. If you plan to disassemble the bed frequently, be careful, as the holes can enlarge from too many assembly and disassembly cycles.
Thanks for the previous answers. A follow-up question: I've noticed that some users especially praise the stability of the side panels, while others see it as a weak point. How exactly do you secure the slatted bed bases in the Brimnes? Is there a clever method that isn’t mentioned in the instructions? Something like reinforcements or additional brackets. Or is the original setup sufficient? I would also be interested to know if it’s worth making any custom adjustments here.
PeoDaniel21 Oct 2024 11:46Hello, I had similar considerations. Basically, the original fastening is sufficient as long as everything is installed properly. It is important to secure the slats of the bed base precisely with anchors and screws. A tip: before the final fastening, check if everything is aligned correctly and the slats lock in well, so nothing will wobble later. If you feel you need a bit more stability, slight improvements can be made with small wooden wedges or additional wooden strips at the contact points. However, this is often not necessary if you follow the instructions carefully.
laelge schrieb:
Or is the original enough? I’m also curious if it’s worth making some custom adjustments here?I’d say this: If you prioritize perfect long-term durability, you can’t beat the original with solid wood or even metal parts. Ikea designs for the lowest possible prices and quick assembly, so compromises are inevitable. Still, the Brimnes is great for normal everyday use. The only drawback is that many users rely too much on the material technology instead of simply making small improvements themselves. If you’re handy, it’s worthwhile.
