ᐅ What types of wood treatments do you recommend for Ikea Platsa?
Created on: 8 Feb 2023 18:37
silirenHello everyone,
I am currently planning to assemble an Ikea Platsa system at home and am looking into wood treatment options. Since the material is usually coated or painted, I am wondering which types of treatments are effective for improving durability and appearance.
Are there specific oils, waxes, or varnishes that are particularly recommended for the Platsa wood surfaces? Any tips on surface preparation before application, such as sanding or cleaning, would also be appreciated. I am mainly aiming for a natural look, but protection against scratches and moisture is also important.
I look forward to your experiences and recommendations on the best wood treatments for Ikea Platsa!
siliren schrieb:
Are there any special oils, waxes, or varnishes that are particularly recommended for Platsa wood surfaces?Hi! The wood in Platsa products is often pre-treated at the factory, but you can refresh the surface with a good wood oil if you want to "bring it back to life." I would recommend a matte natural oil – it highlights the grain nicely and feels pleasant to the touch.
- Lightly sand beforehand with fine sandpaper so the oil absorbs better.
- Apply preferably with a lint-free cloth and not too thickly.
And don’t worry about the effort – it’s really enjoyable and feels like a little wellness treatment for your furniture! 😉
For scratch protection, I’d suggest using small felt pads to prevent any scratching on the edges.
meGreg schrieb:
with Platsa, the wood is often pre-treated at the factoryThat is correct. The Ikea Platsa modules usually have an eco-friendly melamine resin coating or laminated surfaces that make them durable. Applying oils or waxes afterwards is generally only useful if you have sanded the surface or want a completely different finish.
Important to note:
- Treatments like oiling or waxing do not penetrate melamine or paint layers.
- A final coat of paint or varnish can be helpful to protect untreated wood (e.g., cut edges).
Summary: If the surface is still original, I would not recommend applying oil or wax, as it will not adhere to the coating and might negatively affect the appearance.
gesar32 schrieb:
Treatments like oiling or waxing do not penetrate melamine or lacquer coatings.That sums it up well – to add: if you want to modify the Platsa elements yourself, for example if you have cuts with exposed, untreated edges, these edges can be treated with special edge protection oils or linseed oil. This protects against moisture and prevents the wood from swelling in those areas.
If you plan to expose Platsa to more demanding conditions (kitchen, wet room), water-based acrylic varnishes also seal the surface well without looking unnatural.
Other helpful tips:
- Clean the surface with a mild detergent before applying
- Allow the surface to dry thoroughly afterward
- Apply in thin layers rather than thick coats, repeating as needed
This way, you achieve good protection and avoid unsightly stains or discoloration.
siliren schrieb:
Are there any special oils, waxes, or varnishes that are particularly recommended for Platsa wood surfaces?I want to raise an important question here: What about chemical compatibility? The surfaces of Platsa elements are often coated with plastics, which many oils and waxes do not adhere to properly.
Therefore, it is advisable to test the treatment on an inconspicuous area first. Additionally, varnishes have poor adhesion on melamine surfaces, so using a sanding primer or adhesion promoter before applying varnish may be necessary.
More clarity can be gained from manufacturer information or technical data sheets, although these are rarely available from Ikea.
My advice: If you really want to refinish the surface, you should carefully sand the original finish beforehand to remove the coating layer. Otherwise, you won’t achieve good adhesion, which can lead to long-term chipping.
