ᐅ What tips and tricks can make assembling the Ikea Metod kitchen system easier for beginners?
Created on: 21 Mar 2018 10:17
kenjonHello everyone,
I am about to assemble my new IKEA Metod kitchen and am looking for proven tips and tricks that can help even beginners make the assembly more efficient and less frustrating.
Although the instructions are detailed, they can still be quite challenging for someone without much practical experience, especially when it comes to assembling the cabinets and aligning the fronts.
What tools, methods, or small techniques do you find useful to avoid common mistakes and achieve a smooth, clean installation?
I look forward to your experiences and recommendations!
MATHIASDO21 Mar 2018 10:43The question is quite interesting, but it should not be forgotten that the IKEA Metod assembly follows an industrial standard and is not entirely intuitive for complete beginners.
For me, the question is how many “beginners” actually intend to complete the assembly entirely on their own, and whether it might be advisable in general to consider professional help if the installation becomes too complex.
From my own experience, I would recommend reading each step carefully beforehand, numbering the components, and not getting discouraged by the large number of screws and fittings. Another tip is to always organize the work according to the chapters in the manual and only move on to the next step once you have fully understood and completed the current one.
In addition, good lighting and a tidy workspace are often more important than supposedly very powerful tools. While craftsmanship can hardly be replaced, preparation is everything.
kenjon schrieb:
The instructions are detailed, but for someone without much DIY experience, they can sometimes be quite challenging
Hi everyone! I can only encourage you not to see the IKEA Metod assembly as a monster that will overwhelm you!
I personally assembled the kitchen as a complete beginner, and with a few tricks, it goes smoothly!
- Use screwdrivers with a good grip – they give you much better control than cordless drills.
- Work in pairs – it’s very motivating and makes handling the heavy cabinets easier!
- Arrange all screws and parts on a tray – otherwise, it’s easy to lose track!
- Watch videos in advance that clearly explain many problems visually (without them, some steps are really hard to imagine).
With enthusiasm and good helpers, it’s a lot of fun! I wish everyone who is about to start assembling good luck!
Oh yes, assembling can really be challenging if you don’t know where to start! But don’t worry –
- First, make an overview of the parts you are going to assemble.
- Be especially careful to only tighten all screws by hand initially, and fully tighten them only at the end.
- Another great trick is to use tape to temporarily hold cabinets in place while attaching fittings – this makes it much easier to align them!
This takes a lot of stress out of the process, especially if you realize on the spot that something doesn’t quite fit, without having to take everything apart right away.
Good luck, you’ve got this!
As a supplement, I would like to share a very important tip that many people underestimate:
- Use a spirit level at every step when assembling the cabinets. This is the only way to ensure that the fronts are properly aligned later and nothing is tilted.
Even though this advice may sound obvious, small inaccuracies in the IKEA Metod system can quickly cause problems with the functioning of hinges and doors.
Additionally, highly recommended:
- Take photos of each step before assembly in case you have questions in the forum. This makes getting support much easier.
These are practical tips that, in my opinion, often ensure a successful assembly process.
It is true that all the mentioned tips help, but I would also like to add a small organizational advice:
- Allow enough time and try not to complete everything in one day. Even if you are motivated, you will quickly realize that some steps are more complex than expected.
- Take breaks; they help clear your mind and prevent mistakes.
This tip is invaluable. I would add to sort the screws by size and type and to use small containers.
Additionally, it can be worthwhile to test each tool use beforehand on a scrap piece so you don’t lose time later due to mistakes.
fepau schrieb:
Lay out all screws and parts sorted on a tray – otherwise, it is easy to lose track!
