ᐅ What tips or techniques are there for perfectly aligning Ikea BESTA doors?
Created on: 22 Apr 2022 08:17
Diken
Diken
22 Apr 2022 08:17
Hello everyone, I just assembled an Ikea Besta shelving unit and am struggling with perfectly aligning the doors. My question is: What tips and tricks do you know for adjusting the doors, which can be very sensitive to small tweaks, so that the gaps are even and the doors close flush? I’m especially interested in how you deal with the often minimal adjustment options on the hinges and whether you have any advice on the order of assembly or special tools that make the process easier. I’m really looking forward to your experiences and detailed suggestions to help me quickly troubleshoot this.
BENBI
22 Apr 2022 09:02
Hello Diken, your question is right on point, as aligning Ikea BESTA doors can indeed be a bit challenging. Here are some steps that always work for me: - First, it’s important to tighten all the screws on the hinges only by hand, so you still have some play for adjustments. - BESTA doors usually have three adjustment screws per hinge: one for height adjustment, one for lateral movement, and one for the door pressure. Use these specifically to compensate for minor misalignments. - Make sure the cabinet carcass is perfectly level, since any imbalance will affect the door alignment. A spirit level is helpful to check the general positioning. - During installation, I recommend hanging the doors roughly at first and then making adjustments step by step, instead of fixing them tightly from the start. - If you still encounter gap issues despite careful adjustments, slightly tweaking the hinge screws in small increments of half a millimeter or less can sometimes help. Have you also checked if your hinges are still the original models? Sometimes there are slight variations that make adjustments more difficult. Best regards!
TELAHAU
22 Apr 2022 09:45
Door adjustment with BESTA: Loosen the screws, align the door, tighten the screws – repeat the process until everything fits perfectly.
raulso
22 Apr 2022 10:03
I completely understand the frustration – BESTA doors can sometimes just refuse to cooperate. But a small trick worked wonders for me: I place a thin sheet of paper in the gap, align the door, and then tighten the screws. This way, I simulate a small gap beforehand, and in the end, the doors fit much better. Sometimes, it’s the simplest solutions that make the difference!
noge58
22 Apr 2022 14:36
I completely agree with raulso! I just adjusted the doors on my sofa, which is made with BESTA components, and using the paper trick made everything look like new! Just keep at it and stay observant – you’ll discover many small adjustments that can improve the outcome. Good luck, you can definitely do it!
BENBI
23 Apr 2022 07:54
TELAHAU schrieb:
Door adjustment on BESTA: loosen screws, align the door, tighten screws – repeat this process until everything fits.
This is correct and serves as a basic guideline, but especially with BESTA, it is advisable to follow the adjustment sequence carefully. It’s best to start with the height adjustment, then proceed with the lateral adjustment, and finally adjust the depth or closing tension. Equally important is to make all adjustments in small increments to avoid misalignments that can be difficult and time-consuming to fix later. Are there any spots during your assembly where the doors are rubbing against each other or the cabinet frame?
