ᐅ What tips are there for removing Ikea Brimnes drawers more easily?
Created on: 18 Jun 2021 09:37
loman55
loman55
18 Jun 2021 09:37
I am currently having trouble with the drawers of my Ikea Brimnes bed frame, as they are very difficult to pull out and especially hard to put back in. It is particularly tricky when I want to remove them completely, without causing any significant damage to the materials or the mechanism.
My question to the community is specifically: What tricks or proven techniques are there to make it easier to remove the Ikea Brimnes drawers?
I am especially interested in advice regarding the drawer slides themselves, possible locking mechanisms, and recommendations for careful handling in case tools or special techniques are required.
Who has practical experience here and can share helpful tips to make the removal process easier and safer?
jotisi
18 Jun 2021 10:14
I think this question is good because most people just pull Ikea furniture drawers out forcefully and later complain about damaged parts. In my opinion, the problem here is that while Ikea has cleverly designed the drawers, the whole removal system on the Brimnes drawers is somewhat complicated and not very ergonomic.
However, I claim that many people are applying force in the wrong place and forget that these drawer slides have a specific release mechanism that is often overlooked.
My provocative tip: Using brute force is the wrong approach. Instead, first carefully inspect the slide on the side to see if there is a small plastic tab or lever that needs to be pressed—or pressed while simultaneously pulling the drawer out.
Many people reach for tools here, which I find risky because this can easily damage the plastic parts.
For those who know the mechanism, the drawers almost come out by themselves—but only if you know how to properly release the lock.
I’m curious to see if any even more practical insider tips will be shared here!
SUDAN
19 Jun 2021 15:48
Good and very precise question! I would like to provide a structured guide here that can help make it easier to remove Brimnes drawers without damaging the furniture.
First, it is important to understand that Brimnes drawers are mounted on runners with a simple locking mechanism. Often, two small plastic clips on the side frame’s rail system secure the drawer in place.
My recommended procedure:
- Carefully open the drawer all the way to the stop
- Use your fingers to work on the plastic tabs on both sides of the rail – these need to be gently pressed inward (or upward, depending on the model) at the same time
- While pressing the tabs, pull the drawer outward along the rail
- Important: Do not pull the drawer downward or mix pulling and pressing motions, as this can damage the plastic clips
A common mistake is a sudden jerk or using tools like a screwdriver between the drawer and the cabinet frame. This often results in damaged plastic tabs.
Summary: A delicate touch is required; the plastic tabs are small but designed specifically to hold the drawer securely while still allowing easy removal.
If someone is more familiar with the model: I can gladly provide a detailed step-by-step guide with pictures from memory.
glamo
20 Jun 2021 11:22
SUDAN schrieb:
Open the drawer very carefully all the way to the stop
Exactly, this step is essential because the drawer needs to reach a specific position for the locks on the runners to be accessible.
I want to go into more detail here since I have removed and reinstalled several Brimnes drawers myself and am familiar with the system.
Technically, Ikea uses a so-called "push-catch" mechanism on the runners of Brimnes drawers. It consists of small spring-loaded plastic hooks that initially sit in a guide when the drawer is pulled out and are only released by a defined movement.
Here is my detailed tip:
- Open the drawer fully until it really cannot go any further.
- Grab the side of the drawer where the metal runners are visible.
- You will find the locking claws about halfway along the runner as small plastic tabs sticking outward.
- You need to gently press these tabs toward the drawer center (not pull), which releases the drawer.
- At the same time, pull the drawer straight out slowly.
- If possible, support the drawer slightly lifted with one hand to relieve the engaged plastic hooks.
Important: Never pry or use excessive force, as the plastic can easily break or the runner can bend.
Does anyone have experience with whether regularly lubricating the runners with some silicone spray also makes removing the drawer easier? In theory, it should help because the sliding becomes smoother, but I am not sure if that might damage the plastic.
How do you handle this?
