ᐅ What to do about wobbly IKEA PLATSA shelves?
Created on: 5 Jun 2024 08:17
AMINKLA
Hello everyone, I have installed several IKEA Platsa units on the wall and have noticed a slight wobbling, especially when the shelves are loaded. My question is how to effectively and permanently eliminate this wobbling? I have checked the basic setup; the units are properly assembled and attached using the IKEA mounting brackets, which I consider stable. However, I still feel a bit of movement, particularly at the corner joints. Does anyone have experience with tips or tricks to secure wobbly Platsa units against swaying or rocking? Thank you in advance for any advice! Which additional measures provide the most stability?
Dopoki
7 Jun 2024 09:22
When retightening, it is best to use a torque wrench if available. This prevents over-tightening and damage. Small rubber washers under screw heads can also help reduce vibrations.
Franck
7 Jun 2024 09:47
Very important: Loosen the screws first and then tighten them again, instead of tightening them directly. This helps prevent misalignment and increases holding strength.
AMINKLA
7 Jun 2024 10:15
fiman schrieb:
Securing screws with a bit of threadlocker or adhesive
Thank you very much! Are there any recommendations for suitable threadlockers that can be safely used in household environments? I want to avoid anything that might make the screws unusable later or cause damage when removing them.
Lorukeo
7 Jun 2024 10:43
For furniture, removable thread lockers such as medium-strength threadlocker (e.g., Loctite 243) are suitable. They prevent loosening due to vibrations but can be removed with tools during disassembly. This is the best option for home use, as it does not permanently damage the screws.
bauku
7 Jun 2024 13:52
Exactly! I only used Loctite 243 and was able to disassemble my furniture easily when needed. It provides enough strength to hold everything firmly, but not so much that it damages the screws.
AMINKLA
8 Jun 2024 08:21
Great, I will try the thread locker and then gradually optimize the assembly and load. Thanks again to everyone for the detailed and helpful contributions here. The forum is really a great help with technical questions like these!
