ᐅ What to do about loose screws on Malm beds?
Created on: 22 Oct 2017 18:37
JANJE48
JANJE48
22 Oct 2017 18:37
I have noticed for some time that several screws on my Ikea Malm bed are loosening, especially those at the joints between the bed frame and the slatted bed base. This is no surprise since the bed is regularly used, but the screws seem to come loose repeatedly, making the bed wobbly. My question is: What methods or aids do you recommend to tighten these screws securely and ensure they stay tight over time? Are there specific tools, thread-locking compounds, or tricks that have proven effective? I want to avoid the bed becoming unstable again after a short period or the screws getting damaged. Thanks for your advice!
Aimee
22 Oct 2017 19:05
Simply tightening with the appropriate hex key usually helps. If the screws still become loose, you can use thread-locking fluid (such as Loctite). Make sure to fully loosen the screws first, then apply the fluid and retighten. This way, everything stays secure and tight.
BERONAR
22 Oct 2017 20:12
Aimee schrieb:
Can you use threadlocker
IKEA fans like to recommend this, but is it really a good idea? Threadlocker can cause problems later if you ever need to remove the screws. Why not just regularly tighten them as needed? Also, Malm beds are not designed for permanent fixing with threadlocker but are lightweight furniture—you should focus on stability through proper assembly rather than relying on chemicals.
dinano
23 Oct 2017 07:56
BERONAR schrieb:
Why not just tighten them regularly?
That’s an interesting point, but regularly retightening is not a permanent solution; rather, it addresses the symptom rather than the root cause. The real question should be: why do the screws loosen? Often, this is due to the material quality, the load, or the assembly method.
Therefore, I recommend securing the screws with a rubber ring or a plastic washer to help maintain the tension. Alternatively, a slight modification, such as using screws with an improved thread profile, can help. Before resorting to chemical methods, mechanical causes should be analyzed.
mintra
23 Oct 2017 10:23
On professional procedure: The material of the Malm bed mainly consists of particleboard and relatively soft screw connections, which can loosen over time. For retightening, I recommend using suitable hex keys according to ÖNORM ISO 2936 to avoid damage.
For long-lasting stability, threadlocking adhesives based on anaerobic compounds (e.g., medium-strength Loctite 243) are advisable, as they secure the screw threads without preventing later disassembly. Alternatively, for unusual loads, you can use lock washers or small plastic washers that help dampen vibrations.
In conclusion: A regular maintenance check, for example every 6 months, should be scheduled to inspect the connections.
