ᐅ What should you do if the screws in Ikea Metod cabinets become loose during furniture assembly?
Created on: 23 Jan 2019 09:12
BilosuHello everyone, I’m looking for your experiences or solutions on the topic: “What to do about loose Ikea Metod screws in furniture assembly?”
I recently assembled a Metod cabinet, and after a few weeks, I noticed that some of the screws in several joints are no longer tight—some are quite loose. Ikea Metod typically uses cam lock and Spax screws, and I suspect that the material has been subjected to repeated stress or that the engineered wood around the screws has loosened.
In my experience, longer use or continuous load can cause the screw connections to weaken, but I want to take the right steps without having to disassemble the furniture completely or buy new cabinet parts.
Does anyone have tips on the best approach? Are there tricks to fix the screws properly again or replacement parts that hold better?
Thanks in advance for your helpful responses!
jordanvin23 Jan 2019 09:47Bilosu schrieb:
I recently assembled a Metod cabinet frame, and after a few weeks, I noticed that some of the screws at the joints are no longer tight.Hey, I totally understand that! I love Ikea too, but loose screws in Metod units can definitely be a problem 😅. The best approach is this: unscrew the loose screws and carefully fill the holes a bit with wood filler or wood glue and small wooden pieces, so the screw can grip firmly again. Be patient, let it dry first, then slowly screw it back in. This really improves the hold!
One more tip: if possible, replace the original screws with slightly stronger ones. That way, you can avoid having to tighten them repeatedly. Good luck—you’ve got this!
Hello Bilosu,
Regarding your issue with the loose Ikea Metod screws, I can recommend a somewhat more systematic approach based on my experience. The screws in Metod furniture are usually installed in wood-based panels with a thickness of about 18 cm (7 inches), which is not always ideal for repeated stresses.
- First, check whether the holes in the wood are already frayed or enlarged. In this case, you can try filling the holes with wood glue and wood shavings or small wooden dowels.
- Alternatively, there are special repair kits with polystyrene beads for such purposes, which are mixed with wood glue.
- After filling, you should only reinsert the screws after allowing sufficient drying time.
- If none of this helps, it is advisable to replace the affected screws with longer or thicker ones, without damaging the structure.
Although this is a bit more involved, it prevents future problems and maintains the stability of the furniture. If you need details on any of these points, I’m happy to help!
Tevin schrieb:
Alternatively, there are special repair kits with polystyrene beads for such purposes, which are mixed with wood glue.Thank you for the detailed tips! Could you please provide more information about these repair kits? I have heard of "wood fillers" or "repair putty," but I’m not sure if they really hold up in this case. Do you think they can withstand the force when tightening the screw multiple times?
I’m also interested to know if this kind of solution works well in the long term for typical IKEA-style particleboard panels, or if it’s more of a temporary fix.
Hello Bilosu,
In general, these repair putties or mixtures with expanded polystyrene beads are indeed a well-established method to fix stripped screw holes in wood-based materials. They fill the hole and provide the screw thread with a better surface to hold onto.
However, it is important to screw in the screw carefully after the material has dried, without overtightening, so that the material does not crack again. With repeated and strong retightening, the material will eventually reach its limit – in such cases, a longer or slightly thicker replacement screw may work better.
Over time, it is advisable to monitor the load on the piece of furniture and replace worn cabinet parts if they are subjected to heavy use.
I hope this helps!
Bilosu schrieb:
Do you think it will withstand the force when repeatedly tightening the screw?
I hope this helps!
