ᐅ What to do if Malm drawer handles are damaged?
Created on: 17 Nov 2022 08:33
HARRISME
HARRISME
17 Nov 2022 08:33
I have an issue with the drawer handles on my Malm chest of drawers: the handles are made of plastic, and some of mine are either cracked or have small breaks that make it difficult to pull the drawers.
I’m interested in hearing your recommendations for damaged Malm drawer handles. Should the handles be completely replaced, repaired, or is there a proven method to fix such damage without having to disassemble the entire chest of drawers?
If you have experience with this issue, I would greatly appreciate your tips and advice on how to best maintain or replace these frequently used but relatively fragile parts.
Thanks in advance!
barle
17 Nov 2022 09:06
If the handles are damaged, it is best to buy completely new ones. Either original ones from Ikea or suitable replacement handles. Repairing usually doesn’t help much because they are often brittle.
gregto
17 Nov 2022 09:45
I understand your problem well. The Malm series is popular, but these handles can become brittle over time. You have several options:
1. Buy new handles: Ikea offers replacement handles separately, which is usually the easiest and most durable solution.
2. Temporary gluing: Using a strong plastic adhesive, you can repair small cracks for light use, but this is more of a quick fix.
3. Alternative handles: If the original handle is no longer available or too expensive, you can consider other handles that fit similarly.
I would not recommend repairing with screws or reinforcements, as this can affect both the appearance and function.
Good luck with the repair!
Jensson
17 Nov 2022 10:22
Hello HARRISME,
to address your issue with damaged Malm drawer handles in a more structured way, here is a brief guide:
1. Check condition: Are the handles just cracked or is material missing? Are the screws still tight?
2. Get replacements: Ikea sells replacement handles, usually under "Malm handle" or "Malm drawer handle." If you want to use the originals, I recommend buying these directly as they fit exactly.
3. Disassembly: The handles are fixed from the inside with screws – carefully remove them.
4. Consider alternatives: If you want something different, you can look for drawer handles at hardware stores, but make sure to compare the measurements!
5. Repair: Small cracks can be stabilized with plastic adhesive (e.g., super glue or special construction adhesive). Do not apply too much stress, otherwise they will break again.
6. Installation: Tighten the screws properly but not too much, as plastic can break easily.
gregto schrieb:
Temporarily glue: With a strong plastic adhesive, you can repair small cracks if the drawer is used lightly
I add: For heavier use, replacement is really better.
I hope this helps!
barle
18 Nov 2022 07:52
If your handle is loose, often tightening the screw a bit more or using a washer can help.
BOSULE
18 Nov 2022 09:18
Regarding damaged Malm drawer handles, I would like to add that the handles are often made of ABS plastic or similar materials, which can become brittle over time. This frequently leads to cracks or chips.
Repairing with glue only makes sense if the handle is not load-bearing, such as decorative handles. For drawers that are used regularly, I recommend replacing the handles.
It is also important to choose replacement parts with a good grip to improve handling and prevent further breakage.
A practical tip: When ordering replacement handles, check the screw length, as these are often optimized for the thickness of Malm drawers. Using longer screws can damage the material inside.
This will help you avoid future problems.
