ᐅ What to Do If You Have Problems with IKEA Metod Assembly Fittings?
Created on: 31 Jan 2023 18:14
mateo7
Hello everyone, I’m currently facing a recurring issue with the IKEA Metod assembly connectors, also known as the fittings used in kitchen installations. Specifically, I’m having trouble securely and precisely inserting the connectors into the pre-drilled holes; sometimes the connector piece gets stuck or cannot be fully locked into place. My impression is that the material of some connectors is a bit stiff, or the wood panel around the holes might be slightly warped or not drilled perfectly straight. Does anyone have specific tips for working with assembly connectors, especially for IKEA Metod? Maybe some tricks to improve fit and durability or to avoid common problems? I’d appreciate any helpful advice!
nedagla
2 Feb 2023 16:59
Hey everyone, I just wanted to chime in quickly since I’ve just assembled a kitchen with Metod myself!
I can only say: keep your spirits up! 😉 The first challenges always take some effort, but once you get the hang of it, it’s really fun.
For me, it helped to follow every step exactly according to the instructions and, above all, to tighten the screws slowly and carefully to avoid bending anything. I also felt that the holes in my kitchen cabinets were slightly different in depth – so I used a wood drill bit to slightly adjust those spots, which made it easier to insert the connectors.
So don’t get discouraged, it’s worth it! Good luck with your assembly!
