Good morning everyone, I have a problem with the doors of my Ikea Brimnes wardrobe that is really bothering me. The doors no longer close properly and appear crooked, causing the wardrobe contents to shift visibly. I noticed that the hinges are unevenly installed and the doors either stick or slightly vibrate when closing, which suggests incorrect adjustment. Has anyone experienced similar issues? If so, how can this be fixed permanently without completely removing the doors or damaging the wardrobe? I am also interested in knowing if there are common assembly mistakes with these Brimnes doors that I should check.
First, check if the hinges are properly seated in the holes and securely screwed in. Often, simply tightening the screws a bit or slightly realigning the hinges is enough. If the doors are sticking, they can be easily adjusted with an Allen key or screwdriver. A complete disassembly is usually not necessary.
Hello spiros39, I am familiar with your description of misaligned Brimnes doors; this is a common issue with Ikea furniture when the assembly is not perfectly precise. Some tips from me: - Check all hinge attachments carefully, as often a screw is loose or the hinge plate is not sitting flush on the cabinet. - Sometimes, simply readjusting the hinges slightly using the built-in adjustment dial can help. - Pay attention to possible warping issues caused by uneven flooring. The gap between the doors should be even everywhere and as small as possible. - If your doors are sticking, rubber bumpers or small washers on the hinges can help reduce the pressure when closing. It is important to inspect step by step and avoid dismantling everything immediately if unsure. If possible, review the assembly instructions again and check that every screw is firmly tightened. It is definitely worth proceeding patiently here.
Elijah42 schrieb:
A complete disassembly is usually not necessary.I can only agree with that; often the problems are just a matter of proper fine adjustment. I once had the same issue, where two screws were just slightly looser than expected, causing the door to hang crooked. After a few turns on the hinge, the doors closed smoothly and flush again – the same principle as adjusting a car door 😄. A small tip: if you do remove the doors anyway, place a cloth underneath to prevent any scratches.
From a technical perspective, when dealing with issues with Brimnes doors, it is important to consider the precise fitting tolerances of the hinges. The IKEA Brimnes hinges allow for three-dimensional adjustment – horizontal, vertical, and in relation to the cabinet edge. Key points for the procedure: - First, loosen the hinges slightly, position the door, and then gently tighten the screws. - Pay attention to any warping caused by uneven floors, which can affect the door gaps. - Check if all original parts are installed and intact, as non-IKEA replacement parts mostly alter the fittings. Warped or unevenly tensioned doors are also problematic and can be corrected through careful readjustment. A complete disassembly is only necessary if the hinges are severely damaged or if the cabinet frame is warped.
Jukin schrieb:
Make sure to check if there might be any warping issues caused by uneven flooring. I will definitely pay extra attention to that, thanks! My floor is indeed not perfectly level, although I didn’t find it to be extremely noticeable. Could the cabinet really be affected that much?
blapau schrieb:
The IKEA Brimnes hinges allow for three-dimensional adjustment – horizontal, vertical, and in the distance from the carcass edge. Is there a specific order to follow when adjusting all three axes? I ask because when I adjust the hinges, I’m often unsure which setting to make first to avoid unintentionally undoing other adjustments.
