I have recently noticed several small to medium damages on the edges of the drawers and doors of my IKEA Malm furniture. Most of the issues are chipped spots or dents that affect the overall appearance. Since I have been using this furniture for several years, I am wondering: what are the best methods to repair edge damage on Malm furniture in a simple and lasting way?
I am mainly interested in understanding the realistic effort involved, which materials are recommended (e.g., edge paint, repair kits, or wood fillers), and what to pay attention to in order to keep the edges stable and visually appealing after the repair.
Do you have any experience with specific products or techniques that work particularly well for this type of furniture? Are there any professional tips that a non-expert should keep in mind to prevent or at least minimize future damage?
Thank you in advance for your insights!
Hello WALTERMI,
Regarding your question about how to repair damage to Malm furniture edges, I’m happy to provide a detailed answer. These pieces are typically made of particleboard with a thin melamine coating or laminated surface, which unfortunately is not very resistant to impacts or scratches, especially on the edges.
First, you should carefully assess the damage: Is the laminate peeling off, are there deep gouges, or just minor scratches? In most cases, the technical term is "edge damage," and there are quite effective home remedies as well as special repair kits available.
As a first step, I recommend cleaning the damaged area thoroughly, removing any dust or loose particles. Depending on the type of damage, you can proceed with the following methods:
1. Edge paint or repair marker: Special edge paints for melamine-coated furniture come in various colors and are suitable for minor damage such as chipped corners or small scratches. They are applied with a brush. It is important to apply several thin layers and allow each to dry properly in between.
2. Wood filler or putty: For larger holes or broken edges, a light-colored wood filler can be used, which can be sanded down after drying and, if needed, matched with paint.
3. Re-gluing edge banding: If the edge is heavily damaged and the laminate is coming off, you can glue on new edge banding. Heat-activated adhesive tape from a hardware store is recommended for this. The surface must be clean and dry before application.
Patience and careful work are key to achieving a good-looking result with all these methods. I wonder, how severe is the damage on your furniture? Are the damages only superficial, or are parts broken off?
Also, it would be helpful to know how much daily wear and tear the furniture is subjected to, for example from children or pets, or if it is used mostly statically. This influences the choice of repair method and the need for protective measures after the repair.
Generally speaking, if you want to repair the edges comprehensively, you can expect to spend around six to eight hours including drying times, assuming you have some skill. I would also caution you that Malm edges are relatively thin, and applying too much filler or paint can quickly lead to noticeable differences in the surface appearance.
If you like, we can discuss the individual steps in more detail.
I would recommend the following: Touch up small chips with a suitable edge paint, repair larger damaged areas with wood filler, then sand smooth and, if necessary, seal with color-matched paint. Edge banding is a good solution for detached veneer. Important: Clean and degrease thoroughly beforehand.
to approach the topic more systematically, here is a brief guide on how to repair damage to Malm furniture edges step by step:
1. Damage assessment: Determine how deep the damage on the edge is. Is it just scratches, chipped veneer, or are there even missing pieces of material?
2. Cleaning: Clean the edge with a lint-free cloth and a mild cleaning agent. It is important that the surface is dry and free of grease.
3. Applying filler: For deeper damage, a fine-textured wood filler is recommended, mixed according to the manufacturer's instructions. Use a small spatula to apply the filler, removing any excess immediately.
4. Let dry: Depending on the product, this can take several hours up to a day. It is important not to proceed too early.
5. Sanding: After drying, sand smooth with fine sandpaper (grit 220-320) to achieve an even surface.
6. Color matching: Depending on the shade of the furniture, you can mix the appropriate color or use a commercially available furniture or edge paint. Always test to ensure the paint does not damage the surface.
7. Sealing: Finally, I recommend applying a clear sealant (e.g., clear varnish) to make the repair last longer.
8. Applying edge banding: If the veneer is peeling or missing, a new edge band can be applied as a finish. The iron-on method, as often described in hardware stores, is helpful here.
I can only emphasize this; otherwise, you may end up with uneven spots.
One more important tip: After the repair, avoid mechanically overstressing the furniture edges to prevent further damage.
If anyone has questions about individual steps, feel free to ask!
FAZAR schrieb:
Patience and careful work are crucial for a neat result.
I would like to add that with Malm furniture, the edge quality is very delicate due to the thin hardboard or particleboard.
It is crucial not to use overly aggressive cleaners that could further damage the laminate. Also, preventing moisture on the edges afterward helps to extend the lifespan.
For significant damage, it is usually not worthwhile to repair only small spots; instead, it may be better to restore the entire affected edge. This results in a more balanced appearance.
I agree with this, especially for frequently used drawers and doors.
KODAN32 schrieb:
After the repair, one should avoid mechanically stressing the furniture edges to prevent further damage.
From my own experience, I can say: if you don’t reach for professional tools right away when repairing, edge paints and repair pens work really well. They’re quick to apply and you can hardly see the damage afterward—if you get the right color, that is :-)
I once had small white chips on my Malm dresser. Just cleaned the area, applied the paint, let it dry a bit, and done. Works great as long as it’s not a large chip, like 20cm (8 inches) or more.
If the damage is really bad, edge banding helps—especially the iron-on type, because afterwards you won’t notice anything at all.
Have fun while working, don’t stress too much—furniture is meant to be used, and a little wear can actually add character 😉
Exactly, less is definitely more.
FAZAR schrieb:
The Malm edges are relatively thin, and if you apply too much filler or paint, differences in the surface quickly become visible.
