Hello everyone, I am currently facing an issue with an Ikea Brimnes cabinet: the back panel doesn’t fit properly on my new sideboard. More precisely, it is either too large or, due to the groove and the way it is fastened, not compatible, so I can’t attach it securely or it ends up crooked in an awkward way. Has anyone had experience with this and can suggest what to do in such a case? What solutions have proven effective when the back panel of the Brimnes model doesn’t fit? I would really appreciate any tips, especially regarding dimensions, alternatives, or possible minor modifications. Thanks!
reoleon4720 Jan 2022 09:18Good morning everyone! I just want to encourage you again: Don’t lose hope! 🙂 When something sticks, it’s rarely a total loss. A little adjustment can make a big difference. I myself have sanded the edges of a similar Brimnes piece with sandpaper, and it worked great. I’m sure you’ll find a solution!
SUFOJE schrieb:
It is important to proceed slowly and carefully. If you’re unsure, practice first on a leftover piece! Thanks for the detailed explanation. I actually took a leftover piece to test on and was able to remove some material using a utility knife and a file. It feels better than I expected.
Regarding your comment, @Lamar, the biggest issue seems to be the groove, which appears to be too small. Tomorrow, I’ll try using a file and sandpaper to see if I can widen the groove slightly without weakening the material too much.
Is there a guideline on the maximum acceptable tolerance? I don’t want to risk compromising the cabinet’s stability.
Good approach, gradually expanding step by step is exactly right. The tolerance for these medium-density fiberboard panels is usually minimal, typically no more than 1-2 mm (0.04-0.08 inches); otherwise, the back panel could actually lose stability or fail to fit correctly. It is important not to overwork it.
A short guide:
- Always work from the groove side, sanding carefully and regularly checking the fit.
- If possible, use a fine metal file for precise adjustments.
- The back panel should fit snugly but without excessive force.
This way, you can ensure that your Brimnes remains stable in the end.
A short guide:
Renchen schrieb:
The back panel should fit snugly, but without requiring much force.After filing and sanding, the back panel now fits perfectly, and the cabinet feels more sturdy than before. Thanks to everyone for the helpful advice!One more question: Is it better to secure the back panel with nails, or is it enough to just press it into the groove? My back panel has small holes for nails, but I’m a bit worried the material might split.
I'm very glad to hear that it works now! For securing the Brimnes, small special nails (back panel nails) work well if you are careful. It's best to insert them slightly at an angle and not force them in to avoid splintering. If you're unsure, temporarily attach the back panel first with mounting tape. However, nails provide extra stability, especially for cabinet systems that need to withstand some load when opening.
