ᐅ What to do if the drill holes in IKEA Metod cabinets are too large?
Created on: 14 Jan 2022 08:42
danyal5
I noticed during the installation of my new IKEA METOD kitchen that some of the drill holes on the cabinet sides are noticeably too large. The problem is that as a result, any dowels or connecting fittings no longer fit securely, which can compromise the stability of the structure. Does anyone have experience or tips on how to best handle oversized drill holes in METOD cabinets? For example, how to most effectively reduce the size of such holes or alternative fastening methods that are durable and secure. I want to avoid the cabinets wobbling or eventually coming apart. Thanks in advance for your help!
GLALEO
15 Jan 2022 10:22
Oh, that sounds really frustrating if the drill holes for IKEA METOD are too big! But I'm sure you can handle it 🙂
I've had similar issues several times, and the best solution for me was to fill the holes with small wooden pieces or suitable dowels, secure them firmly with wood glue, and then drill again. This makes the joint very stable and also looks neat afterward! Don’t stress, with a bit of patience it will work out great. Good luck! 🙂
EDWARD0
15 Jan 2022 14:37
Summary: Use wood glue and wooden dowels, fill the hole, let it dry, then drill again. Nothing complicated, reliably holds.
lajudo
16 Jan 2022 08:17
danyal5 schrieb:
I want to avoid the cabinets wobbling or eventually falling apart.
Then don't cut corners—use wood glue and dowels. Cheap fillers are not a long-term solution.
ANMARCOS
16 Jan 2022 11:59
I really wonder if we are too focused on the IKEA standard holes instead of reconsidering the entire construction. Perhaps these assembly issues are a symptom of a bigger design problem with METOD?
GLALEO schrieb:
with a bit of patience, it works great.
Yes, patience helps – or alternatively, taking it to a carpenter.
