ᐅ What to do if the drill holes in IKEA Metod cabinets are too large?
Created on: 14 Jan 2022 08:42
danyal5
danyal5
14 Jan 2022 08:42
I noticed during the installation of my new IKEA METOD kitchen that some of the drill holes on the cabinet sides are noticeably too large. The problem is that as a result, any dowels or connecting fittings no longer fit securely, which can compromise the stability of the structure. Does anyone have experience or tips on how to best handle oversized drill holes in METOD cabinets? For example, how to most effectively reduce the size of such holes or alternative fastening methods that are durable and secure. I want to avoid the cabinets wobbling or eventually coming apart. Thanks in advance for your help!
lajudo
14 Jan 2022 09:03
If the drill holes are too large, use wood shavings or small wooden dowels glued into the hole with wood glue. After drying, drill again; it should hold then.
ANMARCOS
14 Jan 2022 09:25
I find it interesting that IKEA, especially with METOD, seems to work so imprecisely. Perhaps this is even intentional, to force people to buy more expensive repair kits or make adjustments?
danyal5 schrieb:
The problem is that this causes any dowels or connectors to no longer hold properly, which can affect the stability of the construction.
This happens more often than you might think. I would say you shouldn’t just accept it, but rather insist on better quality or rely on your own solutions.
nonpra
14 Jan 2022 10:11
Patch the wood filler, let it dry, and then drill again. This usually suffices, holds well, and is quick to do.
boelnu
14 Jan 2022 11:03
That sounds really frustrating when the holes are too large. Something like that has happened to me as well, and I also wondered how to repair it safely and neatly without hassle. For me, the tip of using small dowel pieces and wood glue worked well. It’s important to allow enough drying time; otherwise, it won’t hold as well.
If you’re unsure, I would first assemble everything dry and test whether it truly wobbles or if it only feels slightly loose visually. Sometimes the perception is worse than the reality. It doesn’t have to be a professional repair as long as it holds up in everyday use.
hauklo
15 Jan 2022 07:49
Precise and standard solutions for oversized drill holes:
- Use wooden dowels of the appropriate diameter combined with wood glue.
- After drying, drill a new hole exactly in place using paper templates to secure the position.
- Alternatively, the drill hole can be filled with wood filler, but this provides less strength for load-bearing joints.
I do not recommend improvised fillers such as paper or cotton fibers, as they do not provide sufficient stability. METOD consists of modular furniture panels that must withstand point loads, so a professional solution is essential.
