ᐅ What to do if the back panel of your BILLY bookshelf is not staying in place?
Created on: 1 Jan 2024 09:12
Lista
I recently assembled an IKEA Billy bookshelf and noticed that the back panel does not hold properly. Specifically, the thin particle board can be slid in, but it wobbles noticeably and does not fit securely. I installed all screws and dowels as described, but the back panel is not fixed without tension.
My question to the community is: What can be done if the back panel of a BILLY bookshelf does not hold? Are there proven methods to better secure the backing material or alternative solutions? I want to avoid compromising the stability of the bookshelf.
Thanks for your tips and suggestions!
nubar schrieb:
Remove the back panel, apply some wood glue to the groove, reinsert the back panel, and clamp it tightly or secure it with clampsThat sounds like a simple DIY trick I would try without hesitation. You can take your time with it – that way, the shelf will last longer, and you can relax the next time you check your bookshelf 😉
Thank you for all the helpful responses so far!
I will completely remove the back panel again today, clean the groove, and apply some wood glue as suggested by nubar. I will also re-measure based on the advice given.
Attaching the back panel with small nails also seems practical to me, in case the glue alone is not sufficient.
A quick question for Dopoki and Fitigu: Would an HDF board be better suited as a replacement back panel, or would it bear too much of the shelf’s load? Especially regarding the construction in terms of material thickness and fitting into the groove? Thanks!
Lista schrieb:
Would an HDF board be better suited as a replacement back panel, or would it bear too much of the shelf’s load?An HDF board is significantly stronger than the commonly used thin fiberboard, making it well suited for replacement or reinforcement. The thickness is important: 3 to 4 mm (about 1/8 to 5/32 inches) is a good compromise between strength and fitting accuracy.
You should cut the HDF board precisely to the shelf dimensions and, if necessary, smooth the edges with sandpaper. This option noticeably increases stability without putting excessive load on the shelf.
Yesterday, following the useful tips, I fixed the back panel with wood glue and additionally used a few small nails to ensure a really secure hold.
The result is significantly better – the back panel no longer wobbles, and the shelf now feels more stable.
For anyone facing similar issues: careful measuring, cleaning the groove, applying some glue, and mechanical fastening were the solutions for me. Thanks again to everyone involved!
