ᐅ What to do if IKEA HEMNES furniture wobbles after assembly?
Created on: 17 May 2023 08:24
kuto34
I recently assembled a cabinet from the IKEA Hemnes series. After putting it together, the cabinet wobbles noticeably, especially when pulling on the door or giving it a light tap. The wobbling is more than just a slight sway; it feels generally unstable. I followed the instructions carefully, tightened all the screws, and installed the back panel. Still, the problem persists.
My main question is: What are the possible causes of such wobbling specifically with Hemnes furniture after assembly? And most importantly, what can I do to improve the stability without having to completely disassemble the cabinet? Are there any special tips regarding fasteners, the use of washers, or leveling on the floor (e.g., uneven surface)?
I look forward to your experiences and helpful advice!
kuto34
19 May 2023 08:27
A quick update from me:
Yesterday, I tightened all the metal connectors again—there was still a little bit of play in some areas. I loosened the back panel and added missing fasteners using 18 mm (about ¾ inch) furniture nails that I found at the hardware store.
Then, I placed the cabinet on a spirit level and put felt pads under the slightly raised feet to ensure it has solid contact with the floor all around.
Result: The cabinet now stands firmly without any noticeable wobbling.
Thanks to everyone who contributed so thoroughly! Especially the tips from Nakar33 and Lilau were invaluable.
mabla
19 May 2023 10:18
Good to hear! These kinds of steps usually help. If the problem occurs again, just check the fasteners and the base surface.
todunar
20 May 2023 06:54
Great that you managed to fix the wobbling! It really pays off to check everything step by step – that’s how building becomes enjoyable, and in the end, everything is solidly in place! Wishing you continued enjoyment with your Hemnes 🙂
