ᐅ What to do if IKEA Hemnes drawers don’t close properly?
Created on: 13 Apr 2024 09:27
Driesan
Driesan
13 Apr 2024 09:27
I am currently assembling my IKEA Hemnes chest of drawers and have noticed that some of the drawers do not close properly. Specifically, they catch on one side, do not slide in fully, or sit slightly crooked. I have already checked if the drawer runners are aligned correctly and if all screws are tightened, but the problem persists. The cause might be a slight deformation or an incorrect assembly, but I want to examine this carefully.
Does anyone have specific advice on what to pay attention to when Hemnes drawers do not close properly? How can the issue be most effectively identified and resolved? Are there any known weak points with this model? The drawers are not overloaded, and I have also tried carefully removing and reinserting them.
Best regards and thank you in advance for your help!
Filippo
13 Apr 2024 11:53
Hello Driesan,
your issue with the Hemnes drawers sounds like a typical misalignment of the slides or possibly a bent track. I proceed in several steps:
- First, I check the drawer slides on both sides. Especially with Hemnes, it is important that the metal slides are installed exactly parallel and at the same height.
- Next, I use a spirit level to check if the furniture piece itself is truly level. Even a slight tilt can be enough to prevent drawers from closing properly.
- Then I examine the drawer sides; sometimes they become slightly warped or damaged during transport, which can cause sticking.
If you have already checked the screws, my next step would be to completely remove the slides and inspect them for damage. Sometimes the ball-bearing runners inside can jam.
You might also want to check if the drawer front itself is properly mounted, as imprecisely fastened fronts can also interfere with closing.
One more question: Have you tried removing and reinstalling the drawers multiple times? Small misalignments can sometimes occur if the correct insertion technique is not carefully followed.
If you like, I can explain how to optimally adjust the slides.
Mufato
13 Apr 2024 13:16
With Hemnes drawers, the issue is usually caused by misaligned drawer slides. Tighten the screws, align the slides parallel, and check that there are no foreign objects in the tracks.
If that doesn’t help, try removing the drawers completely, clean them, and reinstall them correctly.
bapar
14 Apr 2024 08:44
Hello Driesan,
I would like to go into more detail about the mechanical components of the Hemnes drawers that can often cause issues. Hemnes uses roller bearings with ball bearing guides for the drawers, which can catch if installed incorrectly or worn out.
1. Check the drawer rollers: These small rollers allow the drawer to slide smoothly along the track. If they are dirty or blocked, the drawer will not close properly.
2. Inspect the positioning of the metal guides: If these are slightly misaligned during installation, the drawer may rub against the side panel edging, preventing it from closing completely.
3. Measure the gap between the drawer bottom edges and the interior cabinet walls. Too small a gap can cause friction, while too large can result in misalignment.
4. Rivet or screw connections: With Hemnes, screws can loosen slightly after repeated use, especially where the side panels are attached.
5. General dust or dirt buildup in the sliding track, often overlooked.
My advice: Gently retighten all screws using a torque wrench, clean the runners with a dry cloth, and check that the rollers move freely. If the roller guide is damaged, replacing it may help.
Have you placed the furniture on a firm, level surface? This also significantly affects how the drawers operate.
Lucien
14 Apr 2024 12:37
I would like to agree with the previous posts and suggest some more precise measurement steps to accurately determine why the IKEA Hemnes drawers are not closing properly:
- Measure the installation height of the drawer slides on both sides with a ruler – deviations of more than 1-2 mm (0.04-0.08 inches) can already be noticeable.
- Check the parallelism of the drawer slides using a spirit level or ruler.
- Ensure that the drawer is not obstructed by a warped cabinet or uneven floor.
- In particular, verify that the drawer front is properly aligned, as incorrect positioning can affect closing.
What I also often see is that the drawers are not properly engaged into the slides from below. You should gently press the drawer into the slide until it clicks into place rather than just pushing it in.
Finally, if nothing is found after these checks, it is advisable to loosen all the screws of the slides, realign the slides, and then tighten them again.
It might also be possible to replace the drawer slides with an alternative system if there is a defect in the original.
