I recently bought the Ikea Hemnes sideboard and am generally satisfied with the quality. However, I noticed that some of the doors don’t latch properly when closing. They feel a bit loose and don’t close firmly, so you can sense that they kind of ‘give’ or are not fully engaged. I’ve already checked whether the door hinges are installed correctly, and they appear to be mounted properly with the screws tight.
My question is: What can I do if the Ikea Hemnes doors don’t latch when closing? Are there any specific adjustment options, known weak points, or maintenance steps to try? I want to avoid having the doors constantly left open or getting damaged. I would appreciate any suggestions, tips, or experiences.
Thanks in advance for your help!
if Ikea HEMNES doors do not latch properly when closing, this is usually due to the fine adjustment of the door hinges. These hinges have a special adjustment screw that allows you to change the door position in three dimensions:
- Depth (distance to the cabinet frame)
- Height (vertical alignment)
- Lateral shift
First, you should check whether the door is correctly positioned in the frame. By adjusting the screws, you can move the door slightly closer to the cabinet so that the magnetic catch engages correctly. Often, too large a gap between the door and the cabinet causes the latch not to catch.
It is also worth inspecting the magnets or catches responsible for the latching. These can be affected by dirt, adhesive residue, or minor damage. Cleaning with some isopropanol or a mild cleaning agent can help.
If the adjustment is not sufficient or the mechanism appears damaged, it may be advisable to check the availability of replacement parts from Ikea.
I hope these tips are helpful.
- Lateral shift
draleo schrieb:
If Ikea HEMNES doors don’t latch properly when closing, it is usually due to the fine adjustment of the door hinges.I agree with this. Additionally, I would like to point out the following:
- The doors of the HEMNES furniture often have so-called "push-to-open" magnetic catches. If these are not precisely aligned, the latching mechanism will not work reliably.
- Check the position of the small latch/magnet on the inside of the door. Even a few millimeters (inches) of misalignment can disable the mechanism.
- Also, make sure that the door and the cabinet frame sit flush against each other; there should be no gap that could weaken the magnetic effect.
A systematic inspection and adjustment of the hinges according to the instructions is recommended. Often, loosening a screw slightly and then realigning until the door closes firmly can help.
Some patience is required here to avoid overtightening the adjustment screws too quickly.
Hello alvaix,
I had a similar issue with my HEMNES wardrobe and can share the following from my experience:
1. Check the door hinges carefully. If they are still stiff, it can help to loosen them slightly and then retighten with gentle pressure while holding the door in the correct position.
2. Take a look at the small plastic or metal clips that act as catches – these are usually located near the locking mechanism or magnets. Sometimes they sag or are bent.
3. Also make sure the cabinet body is standing level. A slightly uneven positioning can affect the function.
4. If the problem persists after adjustment, it’s important to know that Ikea provides replacement hinges or locking mechanisms in such cases. A quick call to customer service often helps.
I hope this helps! If you like, I can provide step-by-step instructions on how I proceeded.
Landontau19 Apr 2022 16:11Hello,
to systematically resolve the issue of "Ikea HEMNES doors not closing properly or not latching correctly," I recommend the following approach:
1. Check the hinges:
- Make sure the hinges are securely fastened. If necessary, loosen the screws, reposition the door, and then tighten them again.
- Adjust the hinges using the adjustment screws for height, depth, and lateral movement until the door sits flush against the furniture.
2. Inspect the latch components:
- HEMNES doors often have small magnetic catches or plastic tabs that provide the latching function.
- Check their position and look for any damage.
- Clean the contact points of dust and dirt if needed.
3. Load test:
- Sometimes doors don’t latch if they are warped. As a test, apply some masking tape to the edge and close the door to identify pressure points.
4. Alternative solution:
- If adjusting doesn’t help, installing additional magnetic catches, which are available at hardware stores, can be effective.
If the furniture is still under warranty, customer service can also assist.
I recommend proceeding step by step and not adjusting multiple screws at the same time, so you can clearly see which adjustment has which effect.
3. Load test:
