ᐅ What to do if Ikea HEMNES doors do not hang correctly?
Created on: 13 Jun 2022 18:37
kargerrit
kargerrit
13 Jun 2022 18:37
Hello everyone, I am facing the following issue: I just can’t properly hang the doors of my Ikea Hemnes wardrobe. Specifically, the problem lies with the hinges – the doors don’t sit correctly in the brackets and they don’t close flush. I have checked whether the hinges are properly mounted and loosened the adjustment screws, but the problem remains. The doors also seem slightly warped or at least difficult to align precisely. My question to you is: What can I do if the Ikea HEMNES doors won’t hang correctly? Are there any known tips or specific adjustments that I should be aware of? I would be very grateful for any helpful advice!
JORDON
13 Jun 2022 19:04
Hey kargerrit, that sounds really frustrating when the doors don’t want to hang properly! 😊 The HEMNES hinges are usually straightforward, but sometimes getting the perfect alignment can be tricky. Most of the time, it’s because the hinges or the cabinet frame are slightly misaligned when attaching the doors. A small tip: try hanging the doors at a slight angle first, attaching the top part before pressing the bottom into place. It can help to tilt the hinge head slightly so it slides smoothly into the mounting bracket. After that, the adjustment screws allow you to fine-tune the fit so the door sits flush. It’s important to turn the screws gently and make only small adjustments at a time. Have you also checked the installation instructions again? Sometimes there’s a small detail that’s easy to miss. Good luck with hanging the doors – you’ll get it sorted soon! 👍
Palenar
14 Jun 2022 08:26
Hello kargerrit, to help you properly and long-term, we need to narrow down the problem a bit more precisely. 🙂 You mentioned that the doors do not “hang properly,” meaning the hinges don’t sit cleanly in the bracket and the doors don’t close flush. Here are some points you should check step by step:
- 1. Check the hinges on the cabinet body: Are the brackets really straight and securely screwed in? Sometimes they are slightly crooked or loose, which makes hanging the doors difficult.
- 2. Align the doors: The IKEA HEMNES hinges allow adjustment in three directions – lateral, vertical, and depth. With these, you can position the door panel exactly.
- 3. Warped doors: Wooden doors can warp slightly due to humidity. Check flatness with a spirit level or ruler.
- 4. Inspect the hinge mechanism: Are the hinges moving smoothly? If not, a drop of oil or gently loosening the screws might help.
- 5. Hang the hinges properly: The upper part of the door should be attached first, then place the lower part. It can help to gently press the door inward so it clicks neatly into the brackets.
- 6. Follow the assembly instructions carefully, especially the notes about screw adjustment.
Which step did you complete last? Especially with HEMNES, it’s often just a matter of a few millimeters that make the door catch properly. I would also be interested to know if the doors are new or used and how much experience you generally have with furniture assembly.
GLAEL
14 Jun 2022 09:45
Palenar schrieb:
The IKEA HEMNES hinges offer adjustment in three directions – lateral, vertical, and depth.
This is exactly the key. If the door does not fit properly, fine-tune the hinges one after another. Use the lateral screws to shift the door horizontally, the vertical screws to adjust the height, and the depth adjustment screws to close the door flush. Afterwards, make sure to check that all screws are tightened securely.
