ᐅ What to do if IKEA HEMNES cabinets don’t close properly?
Created on: 19 Oct 2020 08:43
PINNAU
PINNAU
19 Oct 2020 08:43
Hello everyone, I currently have a problem with my IKEA Hemnes cabinets that is really frustrating: the doors on some models no longer close properly, there is always a gap, or they don’t latch correctly. I have already checked if the doors are flush and if the hinges are properly aligned, but somehow this hasn’t solved the issue. Has anyone had similar experiences or smarter tips on how to fix this problem permanently? I think it might be related to the installation or the hinges, but I don’t want to start adjusting things blindly without knowing what to watch out for. Thanks in advance!
sarGabriel
19 Oct 2020 09:11
First, check if the hinges are fully tightened. They are often slightly loose, which usually causes the problem. After that, adjust the door stop; this is usually sufficient.
rimole
19 Oct 2020 10:29
With my HEMNES, it helped to gently tap the doors into the hinges with a rubber mallet to get them to latch properly. Also check the nylon buffers in the corners, as they ensure the door closes correctly.
PINNAU
19 Oct 2020 12:02
Thanks in advance for the tips!
sarGabriel schrieb:
First, check if the hinges are fully screwed in.
I already checked that; everything is securely fastened, but the gap remains.
rimole schrieb:
Check the nylon buffers in the corners, they ensure proper closing.
That’s interesting! I hadn’t realized these small parts are so important. Some of mine are slightly displaced or even missing. Could this really be the cause? Should I reorder them, or are there alternatives that can be used?
GALEO4
19 Oct 2020 13:54
Interesting that everyone immediately suspects the hinges here. In my opinion, the problem usually lies in the cabinets not being perfectly level; the floor or the wall can be slightly uneven.
Why is it expected almost everywhere that you can achieve perfect alignment with IKEA furniture? I argue that a lot of fine-tuning is needed, otherwise a HEMNES cabinet can easily hang 2 millimeters (0.08 inches) out of level – and then no door closes properly.
Just try using a spirit level to check if everything is standing and positioned correctly. This is often underestimated.
V
vinpau
19 Oct 2020 15:21
Oh, such challenges can be frustrating, but hey – they also give you a chance to tackle things with renewed energy! 😄 The important thing is: don’t give up!
I have several HEMNES wardrobes myself, and sometimes just tiny adjustments to the hinges are enough to make the doors close perfectly. It can also help to slightly turn the hinges inward or outward to minimize the gaps.
Give it a try, you’ve got this! And if something gets stuck, we’re all here to help! 😊
