ᐅ What to do if Ikea Brimnes drawers are no longer sliding smoothly?
Created on: 27 Mar 2022 08:32
DanmarHello everyone, I have a problem with the drawers of my Ikea Brimnes wardrobe. Lately, the drawers don’t slide properly anymore; they stick in some spots and don’t open or close as smoothly as before. The drawer slides appear clean, but I feel like something is catching or maybe worn out. Has anyone experienced something similar or knows what to do if Ikea Brimnes drawers grind, get stuck, or generally don’t run smoothly? I would appreciate concrete tips for troubleshooting and possible repairs, or even recommendations for replacement parts. If relevant: The drawers are about 3 years old and haven’t been heavily loaded, just normal books and clothes. Thanks in advance for your help!
Hello Danmar, your issue is quite common, especially with models like the Brimnes series that use drawers with metal runners. I recommend approaching this systematically:
- First, completely remove the drawers and inspect the metal runner tracks both on the cabinet and on the drawer itself. Sometimes small debris, tiny wood pieces, or dust accumulate, preventing smooth sliding.
- Check the rollers or plastic glides that sit in the runners. If these are damaged, cracked, or deformed, they can be replaced. Ikea often offers these replacement parts separately.
- Also make sure the runners themselves are still securely attached. Over time, screws can loosen, causing the runner to shift slightly and create catching points.
- Another common issue is the drawer’s clearance: if the material has warped due to moisture, this can cause increased friction.
I’d like to know if you notice any difference after loosening or cleaning. You might also want to see if using a light oil or silicone spray for lubrication helps. Please also let me know if you have the tools to tighten screws or remove parts if necessary.
If you want, I can prepare a small step-by-step guide with pictures this afternoon, showing how to fully remove the drawers and check the components. Generally, replacement parts at Ikea are relatively affordable.
What do you think, does this sound like a good start?
Surela schrieb:
I recommend taking a systematic approachI completely agree! Loose drawers annoy me a lot too, especially when you’re in a hurry. Sometimes it helps me to pull the drawer out completely a few times and then slowly slide it back in; often you can already feel where it might be sticking.
Sometimes it’s really just a small issue, like a bit of dust or hardened dirt on the edges of the drawer slides. I personally had a case where a small plastic guide on the drawer was cracked and no longer sliding smoothly – a replacement part from the Ikea service helped a lot.
So I would first try removing the drawers entirely, clean the slides, and then check for any damaged parts. And don’t worry, it’s not a big effort – I managed to fix it myself last time, and now everything glides smoothly again.
How do you feel about tackling this yourself? I know it’s not the most fun task sometimes, but in the end, it almost feels like a little success story!
In addition to the previously provided information, here is a precise problem analysis and procedure if the drawers of the Ikea Brimnes no longer slide properly:
- Cause No. 1: Dirt and Deformations
- Systematically check the guide rails for dust, crumbs, and damage.
- Use a dry cloth or light compressed air for cleaning.
- Cause No. 2: Mechanical Defects
- Inspect the plastic gliders and guide rollers for cracks or breaks.
- Check whether all screws securing the guide rails are still tight.
- Cause No. 3: Deformations of the Drawer Side Panels
- Wood swelling caused by high humidity can particularly cause issues.
- In case of deformations, sanding the edges is a possible solution.
Recommendations:
- Lubricants: Use only silicone spray or PTFE-based lubricants; avoid oily substances as they attract dust.
- Spare Parts: Ikea offers metal rail components separately upon request.
I recommend the following procedure:
1. Remove the drawer and guide rails completely.
2. Clean and inspect all parts.
3. Replace any defective components.
4. After reassembly, apply a suitable lubricant.
This procedure is especially advisable if the drawers continue to stick despite cleaning.
If you want more details about the spare parts, I can provide the article numbers.
Recommendations:
Danmar schrieb:
Has anyone else had similar experiences or know what to do if Ikea Brimnes drawers rub, stick, or generally do not slide smoothly anymore?I had exactly the same problem with a Brimnes TV cabinet after about 4 years. In my case, it was caused by a combination of dirty drawer slides and slightly warped drawer bottom rails.
What helped me:
- Remove the drawers and thoroughly clean the drawer slides.
- Lightly sand the edges of the drawer bottom with fine sandpaper, especially where they rubbed against the drawer sides.
- Tighten all screws on the slides.
- Finally, spray a thin layer of silicone spray onto the slides.
After that, everything slid smoothly and reliably again.
Tip: When removing the drawers, be careful to avoid bending the slides. If you have little experience, ask someone to help you. Good luck!
