I have a problem with my Ikea Besta cabinet doors. They close quite stiffly, to the point where I’m concerned they might get damaged or warped over time. The doors are installed correctly, and the hinges are still fine, but closing them is really difficult. Does anyone have experience or advice on what can be done specifically when Ikea Besta doors are hard to close? Are there any technical adjustments or minor repairs that might fix this issue? I’d appreciate any help, as I’d like to avoid having to replace the doors.
Oleli schrieb:
Are there any technical adjustments or minor repairs that could fix the problem?Hi Oleli, yes, this issue is quite common! It often comes down to adjusting the hinges. You can adjust the door hinges in three directions – horizontally, vertically, and in depth. If the door isn’t centered properly, it will be hard to close. Just try turning the adjustment screws with a small screwdriver, and it should start closing smoothly again. 😄
Sometimes, lubricating the hinges or checking the door stop position also helps. A little patience goes a long way!
Wesley schrieb:
You can adjust the doors on the hinges in three directions – horizontally, vertically, and in depth.Exactly, precise adjustment is the first step. Additionally, I recommend:
- Checking if the doors rub against floor elements or surrounding furniture when closing.
- Verifying that the hinges are properly installed and that there are no loose screws.
- Lightly filing the edges if any material residues cause obstruction.
A systematic approach usually eliminates all mechanical obstacles.
Hello Oleli,
I would like to add some more detailed information: In addition to fine-tuning the hinges, it is important to check the correct installation of the doors, especially the position of the upper and lower hinges. Even a slight misalignment during installation can cause the door to be difficult to operate. It also makes sense to inspect the stops and clips to ensure they are properly seated and not obstructing movement. Sometimes the issue is caused by a slightly warped door due to fluctuations in humidity. In such cases, loosening the screws slightly and making corrective adjustments can be helpful. Patience is the most important tool here!
Ianlau schrieb:
A minimal installation deviation can cause stiffness.Exactly. First, check the mounting screws on the hinges. Often, they are simply not fully tightened, which leads to a misaligned position.
