ᐅ What can you do if a BILLY door squeaks or sticks when opening?
Created on: 15 Feb 2016 19:43
barrasmus
I have the following problem with my Billy bookshelf door: When opening, it squeaks quite loudly and sometimes has slight trouble turning in or out—in some cases, it even sticks, making it difficult to open. The door hasn’t been installed for very long, and neither the hinge nor the door panel show any obvious damage or warping. I have already tried applying some lubricant, but without much success.
I’m particularly interested in how to best identify the cause of the squeaking and sticking in a BILLY door, and which steps are recommended to reliably and permanently fix the issue. Are there any special tools or materials that have proven effective? Does the hinge need specific adjustment or replacement, and if so, what should be considered?
I look forward to your experiences and advice!
Hey barrasmus,
great that you tried the tips right away! 🙂
I used to have a squeaky BILLY shelf as well and treated it with a bit of WD-40 – that really helped! Then I took the door off the hinges and adjusted them slightly so the door no longer sticks but opens smoothly.
One tip: While you’re at it, check if the door closes evenly along its entire height. This can prevent squeaking and sticking! Good luck, and let me know how it goes!
bareynaldo17 Feb 2016 08:47pauPierce schrieb:
The BILLY door often has screws on the hinges for adjusting the position.That’s exactly the point: sometimes in forums like these, it’s suggested that everything will be fine with the right adjustment and lubrication – but what if the design simply isn’t ideal? The squeaking and sticking could very well be caused by the product itself, if the material isn’t durable enough for long-term use.
I wouldn’t rely solely on adjusting it; in doubt, it’s better to replace the door entirely or install a professional-grade hinge that’s more robust. Simply tightening the screws doesn’t always deliver the desired result.
