ᐅ What to do about wobbly Malm furniture legs?
Created on: 30 Jun 2022 09:17
Selamifra
I have a problem with my Ikea Malm furniture. The legs of my bedside table keep wobbling, even though I have tried tightening them. It’s not a large movement, but it’s noticeable and somewhat annoying. I’m wondering if there is an easy, long-lasting solution without having to buy new legs or replace the entire piece of furniture.
Has anyone had experience or tips on how to fix wobbly furniture legs on Malm? I’m especially interested in how to improve stability if the thread on the leg or inside the furniture is a bit worn out.
Thanks in advance!
FAVALERIE9
30 Jun 2022 14:45
Mix wood glue with sawdust, fill the hole, let it dry slightly, screw in the screw and then unscrew it. Done.
This method has worked for me for years and is cost-effective.
Selamifra
30 Jun 2022 15:12
PAREL schrieb:
Use wood filler or repair compound (e.g., special wood putty)
Thanks, PAREL! Would you recommend wood filler or wood glue mixed with sawdust instead?
My concern is whether wood filler has enough flexibility, since the furniture legs have to withstand some stress when tightening. Are there differences in durability?
I also think it’s important that the solution is easy for typical DIYers to apply without making major mistakes.
BOSULE
1 Jul 2022 08:37
I’ll add some technical details:
Basically, wooden furniture threads often become worn down because the torque applied when screwing is too high or the screw has been reinserted too many times.
If you use wood filler, you get a relatively rigid structure. This works well if the thread is not subjected to heavy loads and the screw is removed only a few times afterward.
The combination of wood glue and wood dust is somewhat more flexible and can accommodate slight movement, which can be beneficial if the furniture piece experiences temperature changes and varying loads.
For the best results: apply the repair material in several thin layers rather than all at once. This increases stability and reduces cracking.
V
Victor54
1 Jul 2022 09:24
A different thought:
If the wobbling is caused by loose screws, adjusting them with small silicone or rubber ring washers can help. These create additional pressure and also dampen slight movements between the furniture leg and frame.
Selamifra schrieb:
The thread in the furniture part itself is slightly worn out – it feels noticeably stiff when screwing
The term "stiff" rather suggests a clogged or too tight thread. With a worn-out thread, the screw usually feels loose or wobbly. Maybe check both and, if necessary, clean or carefully rework them.
Josefane
1 Jul 2022 10:45
Victor54 schrieb:
The term "stiff" more likely indicates a clogged or too tight thread.
Exactly, such observations should be taken seriously. A thread that is too tight can easily be stripped if you apply too much force.
You should also check whether the screws are correct, for example, the proper length and appropriate diameter. Some Malm models have different leg versions with varying screw sizes.
If the hole in the wood is damaged, repair kits can help. In that case, you need to avoid pulling too hard, not over-tighten by hand, and work carefully.
Another solution: if the screws are slightly too small, using thicker screws or special screws can often improve the hold without much effort.
Selamifra
2 Jul 2022 12:11
Thank you all for your very helpful tips!
I think I will try the combination of wood glue and wood flour, as this approach sounds simple and easy for me to implement. I will also check the screws for the correct diameter beforehand, as Josefane recommended.
The idea of using rubber ring washers also sounds interesting, in case the glue method alone isn’t 100% effective.
I’m happy to share my results if anyone is interested. Thanks again for the detailed explanations and recommendations. 🙂
