Hello everyone, I have a common issue with my Malm bed from IKEA: the bed joints have been squeaking quite noticeably when turning over or sitting down for some time now.
More precisely, the problem seems to be the interaction of the wooden parts at the connection points, likely caused by slight wood abrasion, minimal unevenness, or insufficient fastening, which leads to friction and thus squeaking noises.
Does anyone have tips or proven methods for effectively fixing these squeaky joints? I would like to know whether it is advisable to simply use regular WD-40 or silicone spray, or if it is better to use, for example, felt pads, Teflon tape, or even replace screws or dowels.
I am also interested in how stable the connections remain after such treatments and whether these measures can potentially strengthen them permanently. Thanks in advance for any advice!
Hello Garry43,
With Malm beds, the squeaking noise usually results from friction between wooden surfaces or the connection between metal fittings and wood. Here is a structured approach that can help:
1. Disassemble the bed and check all connections. Loose screws are often the cause, so start by tightening all screws.
2. You can place thin felt or foam strips between wooden surfaces to act as dampers and reduce friction.
3. Alternatively, applying a dry lubricant like PTFE spray (Teflon spray) often reduces the noise very effectively. WD-40 is more of a corrosion protector and lubricant but can become sticky—so silicone or PTFE spray is a better choice.
4. If the joints feel very loose or unstable, it might be worth replacing the dowels or connecting elements (such as wooden pegs or dowels) or reinforcing them with wood glue.
By tightening and reinforcing the joints with wood glue, the connections can actually become more stable than before, but be careful when tightening to avoid damaging the wood.
Good luck with it!
Garry43 schrieb:
I’m also interested in how stable the connections remain after such interventions and whether they can even be permanently strengthened by doing this.
Good luck with it!
NICOLELIS18 Dec 2015 14:47WD-40 is not ideal because it can become sticky.
Use silicone spray or Teflon spray instead. Tighten all screws before spraying.
Felt pads between furniture parts often help reduce noise as well.
To specifically address squeaking joints in the Malm bed, I recommend the following steps:
1. Mechanical inspection: Completely loosen the screws and check the wooden parts for damage and wear.
2. Clean the contact surfaces with fine-grit sandpaper (240 grit) to create smooth surfaces.
3. Applying PTFE felt tape or thin felt strips between the contact surfaces reduces friction permanently.
4. Alternatively, professional silicone sprays are suitable as they do not stick or attract dust—unlike oil-based products (such as WD-40), which only provide short-term relief.
5. Wood glue can be used on seating surfaces if the joints are designed for it, to increase stability.
6. Finally, tighten all screws securely, but avoid overtightening.
This approach has proven effective for wooden frame beds over the long term, maintaining stability while reducing noise.
