ᐅ What to Do About Defects in Malm Furniture After Extended Use?
Created on: 26 Dec 2020 09:17
klaja
Hello everyone, I have a problem with my Malm bed from Ikea, which I have been using for several years now. Recently, various issues have gradually appeared, starting with squeaky slatted frames, loose screws, and now cracks in the headboard. My question to the community is: What are the best approaches when Malm furniture shows signs of wear after extended use? Are repair attempts sufficient, or is it better to rely on replacement parts or professional assistance? What are your experiences regarding the durability and service of this type of furniture? I look forward to your tips and opinions!
SUBEN60 schrieb:
For repairs, so-called anchor and screw repair kits are recommended.Thanks for the specific recommendation. Until now, I only knew about regular wood filler and didn’t realize such repair kits existed.
How would you assess the durability afterwards? Does this basically solve the problem at the screw holes, or is it more of a temporary fix?
Also, do you have any experience regarding how long a repaired Malm can still be used reasonably before major replacements actually become necessary?
klaja schrieb:
How do you assess the durability afterwards?That mainly depends on the load. Using quality repair kits correctly, the repaired joint can regain almost its original strength, especially if dowels and glue are applied properly.
However, long-term durability is limited with particleboard furniture – it is not designed for heavy or extreme loads.
In general, light to moderate loads over 2-5 years are realistically achievable. After that, the furniture should be checked more frequently or an upgrade should be considered.
I think it makes sense to take a practical approach with Malm furniture. These pieces are very popular because they are affordable and functional. If your bed squeaks, has loose screws, or the headboard shows cracks, it’s time to grab a screwdriver and be patient! 🙂
Important: No rocket science needed— a bit of improvisation will take you a long way. And if the headboard is really too worn, you can even cover it with a nice throw or cushions—both stylish and cozy at the same time 😉
klaja schrieb:Personally, I recommend furniture wax because WD-40 is more liquid and can sometimes damage the wood. But the main thing is to get rid of the squeaking! :-)
Should you use WD-40 or special furniture wax for that?
Timofa schrieb:
No rocket science fuss, a bit of improvisation can get you pretty far.Improvisation is useful, but it should always be based on solid understanding. Otherwise, you end up with patchwork that breaks down quickly. I think it’s important not to confuse maintenance with permanent repair.
Some people here mention wood filler and lubricants, but caution is needed with chipboard. The material absorbs liquids and loses strength as a result. That’s why it’s better to use oil-free pastes or solid fillers.
My recommendation: Document your repairs and regularly test their stability to avoid any risks with furniture where safety matters—especially beds!
