ᐅ What tips or tricks can help with modifying an IKEA BESTA wine rack?
Created on: 3 Mar 2015 17:43
lobobar
I am currently planning a remodel of my IKEA Besta shelving unit to convert it into a wine rack. I want to maximize storage space for bottles while maintaining an attractive appearance. Does anyone have useful tips or tricks on how to best modify the shelves?
In particular, I am interested in whether you recommend specific drillings, dividers, or additional supports that make the shelf suitable for wine bottles.
I have also considered partially removing the back panel to create more flexibility but am unsure if that would affect stability.
I would appreciate it if you could share your experiences or detailed instructions so I can avoid mistakes. Thanks!
GLORIA
4 Mar 2015 11:49
Regarding stability: It is essential to secure the shelf to the wall and incorporate cross-bracing elements if you remove the back panel.
For the shelves, I recommend using plywood or MDF with a thickness of at least 18 mm (0.7 inches). These materials provide sufficient stability and allow for precise adjustments.
A practical way to secure the bottles is by embedding round rods, which you can attach accurately with wooden dowels or strips. This effectively prevents the bottles from rolling.
Additionally, I suggest storing the bottles lying flat with a slight tilt of about 5-10 degrees (5-10°) to prevent the cork from drying out, which could affect the wine quality.
Also, consider using surfaces with a matte lacquer or clear sealant that repels moisture for easier maintenance.
V
valerie-tr
4 Mar 2015 13:03
lobobar schrieb:
What would you recommend for cutting in this case? Should I modify the original shelves or install completely new ones?
I personally recommend replacing the shelves. The best results come from new, stable panels, as filling drill holes and frayed edges on melamine surfaces often turns out messy.
For standard bottles, you can adjust the depth to about 34 cm (13 inches) and plan for a height of around 16-18 cm (6-7 inches) per compartment. If you make new shelves, you can precisely position the dowels or grooves.
It's best to cut the panels with exact measurements and sand the edges neatly. If you have a workshop or a kitchen studio nearby, they often offer affordable cutting services.
If you decide to store items at an angle, you can screw small wedges to the back of the shelves. This is a simple solution that doesn’t require much effort.
Evapau
4 Mar 2015 13:44
The back panel and wall mounting are really important. If you remove them completely, be sure to install crossbars or attach metal brackets to keep the shelf stable.
Guyju
5 Mar 2015 08:31
I completely agree. I would like to add:
- It’s best to use heavy-duty brackets for mounting to the wall.
- Visible screws can later be concealed with wooden plugs or filler.
- Small rubber bumpers on the shelves also help prevent bottles from slipping due to vibrations.
When in doubt, invest more time in stability rather than prioritizing an attractive appearance at the expense of safety.
If you like, I can send you a drawing of the construction to make the implementation easier.
