ᐅ What tips can help with assembling IKEA Hemnes furniture in the bedroom?
Created on: 28 Dec 2023 19:42
Miken36Hello everyone,
I am currently planning to furnish my bedroom using the IKEA Hemnes series and was wondering which practical tips really help during assembly.
My question is specifically: What experiences have you had when assembling Hemnes furniture in the bedroom? Are there any tools or methods that make the process easier, for example when aligning the wardrobe doors, assembling the bed frame, or attaching the handles? What common mistakes should be avoided, especially if assembling the furniture alone or with two people?
I am also interested in whether you have special techniques for mounting the furniture to the wall (e.g., wardrobes or dressers) to ensure everything is secure and stable.
I am not looking for general IKEA assembly tips here, but as detailed advice as possible specifically for the Hemnes series and bedroom furniture.
Thank you in advance for your support!
When assembling Hemnes furniture, always make sure to pre-insert all wooden dowels and screws completely before tapping them in.
This prevents the parts from shifting during screwing. Additionally, using a cordless screwdriver with a torque setting helps avoid over-tightening.
Hello Miken36,
I’m happy to provide you with a structured guide for assembling Hemnes bedroom furniture that should help you:
1. Preparation:
- Lay out all parts and screws clearly. Before starting, check that everything is included according to the instructions.
- Use a Phillips cordless screwdriver with a torque setting; clamps are also helpful.
2. Assembly:
- Begin with the largest components (e.g., bed sides or wardrobe panels). Make sure to insert the dowels very precisely to avoid warping.
- Screw the parts together only finger-tight at first, so adjustments can still be made if necessary. Only fully tighten everything at the end.
3. Doors and drawers:
- Adjust the doors using the adjustable hinges. This is the most important step to ensure smooth closing without misalignment.
- Drawers slide more easily if you lightly grease the metal runners before assembly (apply sparingly, avoid grease stains).
4. Wall attachment:
- Always secure large cabinets to the wall (for tipping safety). Use the supplied brackets and screws for this.
- Make sure you use the correct wall plugs for your wall type (e.g., drywall, concrete, or brick).
Common mistakes:
- Skipping the initial alignment of parts.
- Tightening screws fully right away, leaving no room for corrections later.
- Missing or insufficient wall mounting, especially for tall cabinets.
I hope this helps you!
1. Preparation:
2. Assembly:
4. Wall attachment:
Common mistakes:
A detailed addition to the previous tips:
For assembling the Hemnes bedroom furniture, I recommend planning the process in several steps and proceeding with the utmost care. Especially if you are assembling the furniture alone, pay particular attention to stability and ergonomics.
- Tools: In addition to a cordless screwdriver, screwdriver, and hammer, a spirit level is essential. Hemnes furniture is quite solid and can easily appear slightly crooked, which is especially noticeable on cabinet doors.
- Sequence:
- First assemble the largest modules – for example, the bed frame or the wardrobe – and only tighten all connections by hand initially.
- Then check the alignment with the spirit level and make minimal adjustments if necessary.
- Only once everything fits correctly should you fully tighten all screws.
- Handles: Although all handles on Hemnes furniture come pre-drilled, I recommend pre-drilling again carefully with a drill bit of the appropriate diameter before screwing in the handles to avoid splitting the wood. This is especially important if you plan to move the furniture frequently.
- Doors: Be careful when mounting the doors – the adjustable hinges are very useful but often underestimated. Use the included hex key precisely and adjust the doors so that they close properly and do not stick or warp even with fluctuations in humidity.
- Wall Fixing:
- Before drilling, check with a stud finder or metal detector to ensure you are drilling into a load-bearing part of the wall.
- Use anchors suitable for your wall type and secure the cabinet not only at the top but also at least halfway up.
- Helper: Having a helper to assist with alignment and tightening saves a lot of effort. If you are assembling alone, I recommend using aids such as clamps or tension straps.
And lastly: Read the instructions several times, especially before starting to assemble larger parts, to avoid having to undo steps later.
If you have any questions about assembling individual components, feel free to ask.
- Sequence:
- Wall Fixing:
