ᐅ What tips do you have for using the Ikea BRIMNES furniture in a camper or motorhome?
Created on: 22 Mar 2024 18:42
lavin
lavin
22 Mar 2024 18:42
I am planning to use some IKEA Brimnes furniture pieces for my caravan and would like to hear your practical tips in this context. I am particularly interested in advice on securing the furniture during travel, optimal methods of fastening, and also their use in the limited space of a caravan. Are there any experiences regarding modifications to the Brimnes furniture to make it more stable or functional for camping purposes? Additionally, how does storage in the Brimnes hold up under challenging conditions, such as humidity and movement?
I look forward to your detailed tips and experiences that help make using this furniture in a caravan as safe and comfortable as possible.
farGlen
22 Mar 2024 19:07
I secure the BRIMNES furniture to the walls with additional brackets. Movable parts are fixed with straps to prevent rattling and damage during transport.
LOGEMIN
23 Mar 2024 07:36
Regarding the topic "IKEA BRIMNES for use in caravans," there are several details to keep in mind:
- Fastening: The furniture is primarily designed for stationary homes, so I recommend anchoring it securely to the wall. Metal brackets or sturdy screw hooks work well to prevent shifting or tipping during travel.
- Reinforcement: For the drawers, I suggest applying rubber bumpers or felt strips behind the drawer slides to reduce vibration and rattling noises.
- Moisture: BRIMNES is made from MDF and is sensitive to moisture. In a caravan, it's important to treat the furniture with a good protective varnish or at least ensure regular ventilation, making sure no moisture penetrates the drawers or back panels.
- Modifications: If you need more storage space, inserts or organizers can be useful, preferably with removable plastic bins that are more resistant to moisture.
- Installation: Placement is especially important in a caravan. I recommend planning the exact positioning beforehand and possibly using foam wedges to compensate for small unevenness in the floor or walls. This also helps stabilize the furniture.
In summary: With a few precautions, BRIMNES can work well in a caravan, but without additional fastening and moisture protection, issues may arise.
If you want, I can provide you with my list of suitable brackets and installation accessories.
TEOZAR
24 Mar 2024 10:18
Hello lavin,
I also use BRIMNES furniture in my camper and can share a few additional tips from experience:
LOGEMIN schrieb:
Moisture: BRIMNES is MDF-based and sensitive to moisture.
This is very important. For me, extra silica gel packets inside the cabinets helped keep the air dry.
- For securing the furniture, I placed self-adhesive anti-slip mats under the units in addition to fixing them to the wall. This keeps the base from sliding.
- A small modification: I replaced the original drawer handles with smaller ones to reduce protrusion and make better use of the limited space inside the camper.
- I swapped the back panels for thin plywood sheets, which are sturdier and less vulnerable to moisture.
- If you plan to assemble and disassemble the furniture frequently, I recommend using quick-release fasteners at the mounting points. This saves time and protects the screws from wear.
I hope these tips help. If you have any more questions, just ask.
