ᐅ What are some tips for protecting IKEA Brimnes furniture from dust?
Created on: 4 Oct 2020 08:37
ragelaHello everyone, some time ago I bought several pieces of furniture from the IKEA Brimnes series, mainly dressers and display cabinets, which are known for good quality but unfortunately quite prone to dust. Since I often notice dust settling especially in the corners and on the closed surfaces, I’m looking for effective and practical tips to protect the Brimnes furniture from dust without having to wrap them in airtight covers or complicated coverings. Has anyone had experience with specific products, maintenance methods, or indoor climate settings to sustainably reduce dust buildup on this furniture? I would really appreciate practical advice that is both time-saving and gentle on the material. Thanks in advance!
In general, a combination of regular cleaning and maintaining an optimal indoor climate helps to minimize dust buildup on Brimnes furniture. Important points to consider:
- Use antistatic cloths specifically designed for furniture surfaces.
- Surfaces of the Brimnes series are often painted white, so be careful with harsh cleaning agents.
- Avoid excessive air circulation, as it stirs up dust.
- An air purifier with a HEPA filter can significantly reduce the amount of dust in the environment.
- If possible, do not place furniture directly under ventilation ducts or windows.
These measures are scientifically recognized to reduce dust accumulation without damaging the furniture surface.
ragela schrieb:
Since I often notice that dust tends to settle especially in the corners and on closed surfaces, I am looking for effective and practical tips to protect the Brimnes furniture from dust without having to cover it completely with airtight foil or complicated covers.A very good solution is regular cleaning with a slightly damp microfiber cloth, which minimizes dust abrasion and does not spread particles. Additionally, I recommend placing the furniture in an area with as little dust exposure as possible, for example, away from windows or doors that are frequently opened.
Furthermore, the interior—especially for dressers with drawers—can be protected by placing activated charcoal or special dust absorbers inside. Brimnes furniture has relatively smooth surfaces, so light maintenance is usually sufficient.
Finally, it is also advisable to avoid using textiles or decorative items made from materials that shed lint, as these can visibly increase dust accumulation.
roryvin schrieb:
Avoid excessive air circulation as it stirs up dust.This is an important point. Additionally: Since Brimnes furniture often has white, lacquered surfaces, dust visibility can be quite high. Therefore, I recommend two practical tips:
- Invest in an antistatic cleaning cloth. These reduce electrostatic charge, which attracts dust.
- Additionally, you can treat the undersides or edges of furniture with silicone-based furniture polish to make deposits easier to remove. These products are mild and do not damage the surface of the furniture.
Furthermore: If possible, use indoor air filters that capture fine dust particles in your home. This is especially helpful in urban areas.
