ᐅ What tips are there to prevent Ikea HEMNES furniture from wobbling?
Created on: 22 Jan 2020 09:37
Stamatios
Stamatios
22 Jan 2020 09:37
I recently bought some furniture from the Ikea Hemnes series, including dressers and nightstands, and during assembly, I noticed that some pieces wobble slightly or don’t feel completely stable once assembled and set up. This can be quite annoying depending on the floor surface and load. My specific question is: What tips and tricks are there to prevent Ikea HEMNES furniture from wobbling?
I have already checked that all screws are tightened, but the issue probably lies somewhere in the assembly process or the placement location. Are there any special recommendations regarding alignment, additional stabilizers, or perhaps particular techniques during assembly that can help prevent wobbling?
I look forward to detailed and practical advice, preferably with explanations on why certain measures work or don’t work. Thank you in advance!
Garthre
22 Jan 2020 12:14
Basically, the stability of Ikea HEMNES furniture depends largely on the environment and the assembly.
- Be careful with uneven floors: Even small floor irregularities can cause wobbling. A simple solution is to use felt pads or furniture glides to compensate for minor height differences.
- Retighten screws after assembly: Sometimes the carcass components or back panels loosen, so the connections are no longer fully secure.
- The back panel should be installed completely and correctly. It serves as an important stabilizer.
- Avoid overloading or uneven weight distribution: For example, if a HEMNES cabinet is only loaded on one side, it may cause tipping.
If possible, angle brackets can also be attached to the wall as additional support, especially for tall furniture.
These are proven measures with lasting effect.
taudi
23 Jan 2020 08:42
I would like to suggest a simple approach that has helped me several times to stabilize HEMNES furniture and prevent it from wobbling:
1. Check the assembly instructions: It is important to follow every step exactly, especially when attaching the back panel. Often, thin nails or screws are not fully secured here, which significantly affects stability.
2. Level the floor: Use a spirit level to check the placement area. HEMNES furniture is made of solid pine wood and does not tolerate uneven floors well.
3. Fine adjustment with shims: Quiet plastic shims placed under the feet have proven effective.
4. Inspect the screws: Not only on the back panel but all other connection points as well. Sometimes pre-drilled holes are slightly damaged. In that case, replacing the screws with slightly stronger or longer ones (suitable for the construction) helps.
5. Using furniture glue or wood adhesive at connection points can add extra strength – but this depends on whether you want to be able to disassemble the furniture later.
6. Finally: For furniture that is frequently moved or heavily used, wall mounting with the supplied wall anchors is often recommended.
In summary: Wobbling usually results from a combination of construction issues, uneven floors, and possibly missing wall anchoring. A systematic check following this list often provides a solution.
RENMA
24 Jan 2020 15:29
taudi schrieb:
Wobbling is usually a combination of construction defects, issues with the substrate, and possibly missing wall anchors.
I would like to add that in the Ikea HEMNES series, stability is primarily provided by the back panel. The back panel must be fully flush and securely fixed.
Furthermore, here is my overview of precise measures to prevent wobbling:
- Ensure that all fittings (dowels, screws, brackets) comply with specifications and are installed 100% correctly.
- Check for unevenness at the installation site: Use a precise spirit level and, if necessary, use felt or rubber pads to raise the furniture.
- It is strongly recommended to use the supplied wall fixing. Especially for taller furniture, anchoring to the wall is essential.
- When assembling, tighten screws with a torque wrench at medium torque to avoid overstretching the material.
- Handle the back panel carefully: it is often underestimated because it looks thin, but it is crucial for structural stiffening of the furniture.
Conclusion: Wobbling mostly results from incomplete or incorrect assembly, combined with an uneven substrate and missing wall anchoring. The measures listed should each be understood as part of a systematic checklist.
