ᐅ What tips are there for optimizing IKEA PLATSA for small spaces?
Created on: 7 Dec 2020 09:27
temelI would like to start a discussion on the topic: “What practical tips are there for optimizing IKEA Platsa furniture for small spaces?” Specifically, I am interested in how this flexible wardrobe system can be used to make the best possible use of limited space in small apartments or flats. I am especially curious about different module configurations, combinations with other furniture pieces, optimal dimensions, and clever tricks to maximize storage without making the rooms feel cramped. If anyone has experience with narrow, low, or tall versions of the PLATSA system, I would appreciate concrete recommendations – such as tips for adapting to irregular floor plans or installing accessories. Thanks in advance!
Your question about the optimal use of IKEA PLATSA for small spaces is very relevant, especially since this modular system is so flexible, but at first glance, it’s not always clear how to get the most out of limited space. First, I’d like to address some important technical aspects that should be considered during planning.
- Dimensions of individual modules: PLATSA offers different heights (108 cm (43 inches), 180 cm (71 inches), 220 cm (87 inches)), widths (40 cm (16 inches), 60 cm (24 inches)), and depths (40 cm (16 inches), 55 cm (22 inches)). For small rooms, I recommend the narrower options (40 cm deep) as they take up less floor space. At the same time, it’s helpful to use the height of the cabinets—heights around 180 cm are often good in small rooms because vertical space is optimized without feeling too bulky.
- Combinability: You can screw different modules together to create, for example, corner solutions. It’s also possible to integrate add-ons like drawers or open compartments.
- Assembly notes: When combining units, make sure the anchoring is secure, especially if you have tall cabinets in a tight space.
- Storage optimization: I often use inserts (drawer organizers, dividers for drawers) to keep order in small compartments and avoid wasting space through clutter.
- Doors / fronts: For very small rooms with limited movement space, sliding doors—which can be purchased separately—are a good option, since regular hinged doors require too much space.
Finally, I’m curious: Do you already have specific measurements of the room or particular items that must be stored? That would allow for even more precise planning.
I can easily understand how frustrating it can be to set up a compact space as practically as possible. I recently tried PLATSA myself, although at first I wasn’t sure if the system was ideal for my small apartment. One tip that helped me a lot was to plan the furniture so that you don’t place too many heavy cabinet units in the middle of the room, but rather along the walls. This keeps the room open and prevents it from feeling cramped. I also tried to use the system functionally for everyday life: not just for storage, but also as a room divider — with open shelves that can be accessed from both sides. This simultaneously creates more structure.
TEBILO schrieb:I find this question very important, because only with a few basic details can you really help. What exactly do you want to store?
Finally, I’m interested to know: Do you already have specific measurements of the room or certain items that definitely need to be stored?
flo-Theres9 Dec 2020 18:54PLATSA is an excellent choice for small spaces if you keep the following points in mind: - Use modular elements strategically in height to save floor space. - Consider multifunctionality when furnishing; for example, a lower drawer can serve as a seat if you place a sturdy wooden board on top. - Use internal organizers for small items that would otherwise be hard to keep tidy – PLATSA offers many suitable inserts for this. - Make sure to position the cabinets close to the walls to keep walkways as clear as possible. - If the ceiling height allows for 220 cm (7 ft 3 in) modules, these are ideal as they provide more storage without taking up much additional floor space. - The color and material scheme agrar with bright white or light tones helps prevent small rooms from feeling cramped. Overall, PLATSA offers many possibilities through flexible installation but needs to be used thoughtfully. If you like, I can suggest some planning tools or tips for accurately measuring your space.
